Fiesta MK7.5 LED modifications
lilbleh
Added some additional lighting mods.  Projector lights behind the grill,  grill accent lighting,  added additional turn signal / brake light on the rear diffuser.
  • 9 months later...
On 11/29/2018 at 4:37 PM, lilbleh said:
Cool.  Makes it much easier to do the mods.  Meanwhile here are some additional picture of other lighting mods that i have done.
Took out the Ford badge at the back and replaced with illuminated custom type
All door opening handles inside have some illumination
Rear footwell lighting
Ambient lighting on all front and rear footwell comes on when headlight comes on
Factory sun visor did not have any illumination so i changed them both
Added center and left side lighting on the cargo area
Added some illumination on the empty storage space under the air conditioner - mind you European/UK version could be different
Sorry if some of the images are too dark.  Can't take better photos than what it is.  Also the colour of all the blue ones should actually be ice blue,  but the camera always turn it into blue.
Can I ask about how you did the sun visors? Did you get them off a mk8 fiesta or something? As I’ve been looking at this myself.
Absolutely.  I got the visors from aliexpress and changed the led bulb colour to white instead of yellow and just took of the ends and installed it onto the fiesta.  Let me know if you need the link.
Yes please mate, what was the wiring like?
You need to pull wires from the dome lights or some other source such as the acc from the fuse and wire up the visor lights there.  If you want to change the led light colour from yellow to white then you need to get the 3mm white 12v led so that it will fit and then wire up to the visor electrical channel.  The item should be like this one from aliexpress.  However feel free to browse for more competitive priced ones. Let me know if you have more questions or if you buy the necessary parts and then want to install it,  Whatsapp me and I will try my best to guide you.
https://www.aliexpress.com/item/32903969555.html?spm=a2g0o.productlist.0.0.5c9d3a1fmEY6u1&algo_pvid=76a2fae3-34ad-4fe7-bb08-93eac7f1ad9c&algo_exp_id=76a2fae3-34ad-4fe7-bb08-93eac7f1ad9c-10&pdp_ext_f={"sku_id"%3A"65923600011"}&pdp_npi=2%40dis!USD!!30.8!!!!!%402101d8b516570419892984603e7e57!65923600011!sea
  • Thanks 1
Did you remove the headlining to get to the wiring of the light? Or just pull it through. Cheers mate
Just pull through and tuck the wires in the headliner.
  • Thanks 1
  • 1 year later...
Not really an LED modification,  but managed to add this feature (Blind Spot Warning / Blind Spot Monitor) on the car.  Truth be told,  I was pleasantly surprised at the quality of the mirror.  It is very good and the best thing about it is that it reduces glare and dazzle at night from lights of the cars behind you.
