avi Posted December 1, 2018 Share Posted December 1, 2018 2017 Ti x with keyless entry and just found I can no longer open the boot using keyless or even if the car is unlocked for that matter. It only opens if use the remote key boot release button. Any ideas or is it a visit to Ford ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 1, 2018 Share Posted December 1, 2018 Sounds like the boot button may have broken if you can only open it on the fob? Should be under warranty unless you've done mega mileage so a trip to Ford is probably best bet. 1 Quote Link to comment Share on other sites More sharing options...
avi Posted December 1, 2018 Author Share Posted December 1, 2018 11 minutes ago, TomsFocus said: Sounds like the boot button may have broken if you can only open it on the fob? Should be under warranty unless you've done mega mileage so a trip to Ford is probably best bet. Thanks. Figured it might be related to the boot button and have just booked it in with Ford. It's got a 4 year warranty and only done 17k miles so should be covered. Quote Link to comment Share on other sites More sharing options...
Oldster Posted December 1, 2018 Share Posted December 1, 2018 I think the car being locked or unlocked is unrelated to the boot opening keylessly on the button. If you're in the car you don't want someone opening the boot and taking away a suitcase, say, while you're sitting in traffic. Be interesting to hear what Ford have to say. Quote Link to comment Share on other sites More sharing options...
Ormet Posted December 1, 2018 Share Posted December 1, 2018 I had the same issue a year ago. Could not open the boot unless using the remote. The cause was a loose connector behind the bumper. The connector is behind the bumper at the right rear wheel. Easy reachable, just lay on the ground and look up. Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted January 10, 2019 Share Posted January 10, 2019 2017 Ti x with keyless entry and just found I can no longer open the boot using keyless or even if the car is unlocked for that matter. It only opens if use the remote key boot release button. Any ideas or is it a visit to Ford ? Did you get this fixed? Now got the same problem myself, was it the connector behind the bumper, as Ormet suggested? Thanks in advance. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
avi Posted February 19, 2019 Author Share Posted February 19, 2019 On 1/10/2019 at 9:33 PM, Jollyandy said: Did you get this fixed? Now got the same problem myself, was it the connector behind the bumper, as Ormet suggested? Thanks in advance. Sent from my iPad using Tapatalk Pro Yes, it was fixed under warranty. Needed a new boot switch unit. 1 Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 19, 2019 Share Posted February 19, 2019 Yes, it was fixed under warranty. Needed a new boot switch unit.Thanks for your reply, mine goes in tomorrow for a couple of days so they can find and hopefully fix the fault.Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
avi Posted February 19, 2019 Author Share Posted February 19, 2019 3 minutes ago, Jollyandy said: Thanks for your reply, mine goes in tomorrow for a couple of days so they can find and hopefully fix the fault. Sent from my iPad using Tapatalk Pro It took them about 5 minutes to diagnose the issue. Was told I'd need to book it in and it would take a while to fix due to the camera complicating things. Dropped it off and was called about 2 hours later to say it was done. 1 Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 19, 2019 Share Posted February 19, 2019 Mine was in about 3 weeks ago; went to pick it up and was told they need it for a couple of days and would let me have a loan car. Reason for 3 week wait is a shortage of loan cars. [emoji849]Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
avi Posted February 19, 2019 Author Share Posted February 19, 2019 5 minutes ago, Jollyandy said: Mine was in about 3 weeks ago; went to pick it up and was told they need it for a couple of days and would let me have a loan car. Reason for 3 week wait is a shortage of loan cars. Sent from my iPad using Tapatalk Pro That's a pain. 😞 Hopefully it's just the switch rather than something more complex. Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 19, 2019 Share Posted February 19, 2019 That's a pain. [emoji20] Hopefully it's just the switch rather than something more complex.Thanks, I hope so too!Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 21, 2019 Share Posted February 21, 2019 Apparently it’s the switch...only took 2 separate visits and 2 days to diagnose. The new switch should be here tomorrow.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
avi Posted February 21, 2019 Author Share Posted February 21, 2019 2 minutes ago, Jollyandy said: Apparently it’s the switch...only took 2 separate visits and 2 days to diagnose. The new switch should be here tomorrow. Sent from my iPhone using Tapatalk LOL Thankfully the solution should be easy. Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 21, 2019 Share Posted February 21, 2019 LOL Thankfully the solution should be easy.[emoji23]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
avi Posted February 21, 2019 Author Share Posted February 21, 2019 1 minute ago, Jollyandy said: Sent from my iPhone using Tapatalk I think it's a design issue that may cause premature switch failure. It's too easy to lift the boot whilst still pressing the switch rather than the small grip area just behind it. Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted February 23, 2019 Share Posted February 23, 2019 I think it's a design issue that may cause premature switch failure. It's too easy to lift the boot whilst still pressing the switch rather than the small grip area just behind it. Funny you should say design fault, as the new one looks like it’s got drain holes in it. Happily fixed before she gets traded in. Sent from my iPad using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
