Hugh Ashton Posted December 1, 2018 Share Posted December 1, 2018 The voice activation button on my steering wheel doesn't work . Fiesta Titanium x 2016. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted December 1, 2018 Share Posted December 1, 2018 That's a shame. 2 Quote Link to comment Share on other sites More sharing options...
Hugh Ashton Posted December 2, 2018 Author Share Posted December 2, 2018 Apart from the voice control cluster not working, the cruise control cluster isn't working either. Is this a common problem on the Fiestas. Quote Link to comment Share on other sites More sharing options...
isetta Posted December 2, 2018 Share Posted December 2, 2018 on my 2015 fiesta the buttons are very unreliable. sometimes they work (I don't have cruise but have audio and voice control buttons) and sometimes not. Often I can get the one i want working by pressing other buttons, when I find one that works it often seems to prompt all of them to start working again. With vol and channel change I am not that bothered as I can use the buttons on the radio itself but there is not voice button on the radio itself so that is annoying. Been paying up for a least two years. Warranty ran out 2 weeks ago and I never did anything about it so too late now. Quote Link to comment Share on other sites More sharing options...
Cragrat Posted December 2, 2018 Share Posted December 2, 2018 Try to spray some contact cleaner under the buttons. I worked for me. You can slightly lever up the button surround and get a thin nozzle in. 1 Quote Link to comment Share on other sites More sharing options...
TimST2 Posted December 2, 2018 Share Posted December 2, 2018 Try to spray some contact cleaner under the buttons. I worked for me. You can slightly lever up the button surround and get a thin nozzle in.Agreed. I had this on my Fiesta Zetec and solved it this way. Just have a rag handy to soak up any that runs down the outside. Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Zico Posted December 13, 2018 Share Posted December 13, 2018 My voice button stopped working at some point this morning (or at least I only noticed that it stopped working today). I did have some issues with the bluetooth playing up with the phone so tried deleting and re-paring the phone. Tried pulling the bluetooth fuse out and that hasn't done anything for the voice button but the phone seems to ring out when using the radio buttons to manually call out. I have some WD-40 specialist contact cleaner that I am going to try in a few minutes. Fingers crossed that this works. **Edit** The other buttons on the same pad work fine; volume up/down and switch station/hang up/pickup phone work fine. 1 Quote Link to comment Share on other sites More sharing options...
Bobr Posted December 13, 2018 Share Posted December 13, 2018 I sometimes have problems with the cruise control buttons but then they seem to cure themselves. Quote Link to comment Share on other sites More sharing options...
Zico Posted December 14, 2018 Share Posted December 14, 2018 Well I've tried using the WD-40 specialist contact cleaner and no luck. I'm pretty sure that there isn't anything beneath the switch as everything else is fine as I mention. As I pulled the bluetooth fuse the other day (with no change), I also did a Sync Master reset just now (with no change). Either there is something else wrong OR I am missing something. Any other ideas would be appreciated. *Note* bluetooth calling works fine as I took my work phone with me and called my personal phone, answered and ended the call using the steering wheel buttons. Quote Link to comment Share on other sites More sharing options...
