Jamesgreen1994 Posted December 17, 2018 Share Posted December 17, 2018 Hi Everyone, Owner of a 2011 plate Ford Focus which I believe is a MK2 model. All of a sudden today when i press the washer jet button on my indicator stalk the washers both front and rear have stopped working. The window wipers operate fine but nothing happens for the washers. I believe the pipes or jet aren’t blocked because when i press the washer button there is no noise to indicate the washer jet is working. Is there a fuse of some sort that controls all the above. Thanks James Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted December 17, 2018 Share Posted December 17, 2018 2011 was the changeover year between the mk2.5 and mk3. Easiest way to tell is do Ford still make a similar car lol. Quote Link to comment Share on other sites More sharing options...
dtulip8 Posted December 18, 2018 Share Posted December 18, 2018 Hi James, To start with which of these does it look like? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 18, 2018 Share Posted December 18, 2018 It'll be a late reg Mk2.5. The mk3 doesn't have a washer button on the stalk. The pump has probably failed tbh. Fuse is number 136 under the glovebox. 3 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted December 19, 2018 Share Posted December 19, 2018 20 hours ago, TomsFocus said: It'll be a late reg Mk2.5. The mk3 doesn't have a washer button on the stalk. The pump has probably failed tbh. Fuse is number 136 under the glovebox. Yup, definitely check the fuse but I also reckon the pump itself will be the culprit. The wife's MK2.5 Zetec had to have a new pump fitted as the old one died, having seen what was in the screenwash reservoir and clogging the filter I wasn't surprised the pump failed (it was minging). 2 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted December 19, 2018 Share Posted December 19, 2018 Probably frozen mines does it all the time. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 19, 2018 Share Posted December 19, 2018 2 hours ago, F0CUE said: Probably frozen mines does it all the time. Probably a good idea to get some screenwash with a low freezing point if it's a regular issue, especially considering your location! Quote Link to comment Share on other sites More sharing options...
F0CUE Posted December 19, 2018 Share Posted December 19, 2018 42 minutes ago, TomsFocus said: Probably a good idea to get some screenwash with a low freezing point if it's a regular issue, especially considering your location! Yep I'm right next to the sea so probs a good idea lol Quote Link to comment Share on other sites More sharing options...
Jamesgreen1994 Posted December 29, 2018 Author Share Posted December 29, 2018 On 12/18/2018 at 4:15 PM, dtulip8 said: Hi James, To start with which of these does it look like? Sorry for the late reply, my car is the top silver one Quote Link to comment Share on other sites More sharing options...
Jamesgreen1994 Posted December 29, 2018 Author Share Posted December 29, 2018 Thanks for all your replies guys, will check the fuse out tommorow, only thought there was a fuse panel under the bonnet and dint realise it was also under the glovebox. Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted December 31, 2018 Share Posted December 31, 2018 Will be washer pump. Not a hard job to replace. The Haynes manual is your friend. Quote Link to comment Share on other sites More sharing options...
