Albert27 Posted December 23, 2018 Share Posted December 23, 2018 The indicator in the wing mirror is not working. Where do you get the bulbs and what type? And how do you get in there? Thanks in advance and Merry Christmas! Quote Link to comment Share on other sites More sharing options...
mastachaz Posted December 23, 2018 Share Posted December 23, 2018 this type for mirrors https://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/bulbs/interior-bulbs/?481770276&0&cc5_201 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted December 23, 2018 Share Posted December 23, 2018 Mirror glass off, mirror cover off , then turn signal lens will come out 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted December 23, 2018 Author Share Posted December 23, 2018 4 hours ago, iantt said: Mirror glass off, mirror cover off , then turn signal lens will come out Cheers Ian. Dos the mirror glass just pull off or are there screws/clips holding it in place? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 24, 2018 Share Posted December 24, 2018 Don't remove the glass, there's no need and there's a risk of snapping lugs off.Tilt the mirrors down in the casings and use a torch to spot to inverted U shaped notches inside the top of the housing.Push a small screwdriver into both notches and lever down gently to pop the tabs from behind the notches then pull the mirror caps off forward and up.The indicator lenses pop out from the pointed end first and unhook at the thick end.The bulb holders just pull out of the lenses.Sent from my SM-G965F (S9+) 3 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 24, 2018 Share Posted December 24, 2018 View the pictures below-Sent from my SM-G965F (S9+) 3 Quote Link to comment Share on other sites More sharing options...
iantt Posted December 24, 2018 Share Posted December 24, 2018 I pull the glass off, not broke one yet. But clives method is a safer way . 1 Quote Link to comment Share on other sites More sharing options...
mastachaz Posted December 24, 2018 Share Posted December 24, 2018 yes meeto just remove glass and put on top of mirror and remove bulb its simple and nothing break. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted December 24, 2018 Author Share Posted December 24, 2018 I'll go for Clive's option as I'm prone to get into DIY disasters !! Thanks for the replies. 2 Quote Link to comment Share on other sites More sharing options...
mastachaz Posted December 24, 2018 Share Posted December 24, 2018 18 minutes ago, Albert27 said: I'll go for Clive's option as I'm prone to get into DIY disasters !! Thanks for the replies. you want remove more parts 😄 more damages can hapen 😄 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 24, 2018 Share Posted December 24, 2018 A mirror cap is cheaper and easier to replace than the glass. [emoji41]Sent from my SM-G965F (S9+) 1 Quote Link to comment Share on other sites More sharing options...
mastachaz Posted December 24, 2018 Share Posted December 24, 2018 i remove my glass 10 times not problem but removed caps and broke clips so 😄 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 26, 2018 Share Posted December 26, 2018 i remove my glass 10 times not problem but removed caps and broke clips so [emoji1]Hulk hands?Sent from my SM-G965F (S9+) Quote Link to comment Share on other sites More sharing options...
iantt Posted December 26, 2018 Share Posted December 26, 2018 3 hours ago, Stoney871 said: Hulk hands? Sent from my SM-G965F (S9+) And there's you, to much of a wimp to pull a bit of glass off.lol 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 26, 2018 Share Posted December 26, 2018 And there's you, to much of a wimp to pull a bit of glass off.lol I'd crush the glass and rip cables out [emoji41]Sent from my SM-G965F (S9+) 2 Quote Link to comment Share on other sites More sharing options...
mastachaz Posted December 26, 2018 Share Posted December 26, 2018 8 hours ago, Stoney871 said: Hulk hands? Sent from my SM-G965F (S9+) well its easy to break 1 Quote Link to comment Share on other sites More sharing options...
F0CUE Posted December 27, 2018 Share Posted December 27, 2018 It annoys me how scratched the covers get is it as bad on the MK3? Quote Link to comment Share on other sites More sharing options...
Albert27 Posted December 27, 2018 Author Share Posted December 27, 2018 8 hours ago, F0CUE said: It annoys me how scratched the covers get is it as bad on the MK3? Can's say I've noticed Ian but then I ain't that bothered about scratches etc, my mk2.5 is plastered with scratches! Sorry to burst everyone's bubble but the indicator got fixed today......on ts own......! Not sure what the story is there but hope this thread helps someone else in the not too distant future! So if you're bulbs out and you're reading this, slam the door shut a few times, if that fails follow above information.... 1 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted December 27, 2018 Share Posted December 27, 2018 9 hours ago, F0CUE said: It annoys me how scratched the covers get is it as bad on the MK3? The mirrors are identical on MK2 & 3 so they scratch just as easily. But with driving on hedge lined rural roads I'm yet to find any that don't get scratched! 3 Quote Link to comment Share on other sites More sharing options...
