Smax 2.0 tdci oil heat exchanger torque specs
jorgemef
Hi. Anyone can tell me torque specs for the oil cooler of smax 2.0 tdci?
https://goo.gl/images/YGjpQh
Mine is blown and leaking and need to replace it but I cannot find procedure in etis for this version.
Will I need new gaskets as not all kits bring them?
Thanks,
Jorge
Enviado do meu SM-G930F através do Tapatalk
Can you get it separately or is it part of the oil filter housing from ford? May be why ford etis doesn't show torque settings for the screws. If it is separate then gaskets /o rings will probably be separate too.
At Ford I dont know if it is sold separated but at autodoc they sell it.
I checked, ford don't sell it separately. Therefore no torque settings in etis.
Ok. I will use torque from other brands. I saw about 20nm from Bently and Bmw for similar appliance.
I ended up using 10nm. It was a 4x8mm screw into the aluminium body of the oil filter housing. One of the bolts was kind of stripped but still holding. One of the seals for the oil ports which came with the kit was too large so I reused the old one. It is holding for now. Fingers crossed to not get leaks meanwhile.
