wild_one Posted December 28, 2018 Share Posted December 28, 2018 After you've let out the clutch and start to accelerate there is a rattle/vibration that starts around 1500rpm to 2000rpm before it smooths out. More noticeable in the lower gears. You cannot replicate the noise by revving the engine alone. I suspected the DMF but the clutch is faultless in operation, with a strong bite and no noises from it at tickover whether in or out of gear? But, I have this noise/rattle/vibration coming from behind the gearstick area. I was wondering if it could be a failed gearbox mount as its in that location? Quote Link to comment Share on other sites More sharing options...
Ej2itR Posted December 28, 2018 Share Posted December 28, 2018 After you've let out the clutch and start to accelerate there is a rattle/vibration that starts around 1500rpm to 2000rpm before it smooths out. More noticeable in the lower gears. You cannot replicate the noise by revving the engine alone. I suspected the DMF but the clutch is faultless in operation, with a strong bite and no noises from it at tickover whether in or out of gear? But, I have this noise/rattle/vibration coming from behind the gearstick area. I was wondering if it could be a failed gearbox mount as its in that location?I two have this and a clunking sound. I suspect either gearbox mount or rear mount, Sent from my SM-A520F using Tapatalk Quote Link to comment Share on other sites More sharing options...
wild_one Posted December 28, 2018 Author Share Posted December 28, 2018 1 hour ago, Ej2itR said: I two have this and a clunking sound. I suspect either gearbox mount or rear mount, Sent from my SM-A520F using Tapatalk I'm going to have to get it on the jack and have a route around. But the lower gearbox mount can be difficult to evaluate without removing it and examining Quote Link to comment Share on other sites More sharing options...
Ej2itR Posted December 29, 2018 Share Posted December 29, 2018 I'm going to have to get it on the jack and have a route around. But the lower gearbox mount can be difficult to evaluate without removing it and examiningI have only bought my car so didnt get time to check it over a pit. If you have use of a pit it is easy check. Have someone sit in the car started brakes one and in gear have them 'pop' the clutch so as to move engine you should be able to see or hear it.This has worked for me with other cars.Sent from my SM-A520F using Tapatalk Quote Link to comment Share on other sites More sharing options...
wild_one Posted December 30, 2018 Author Share Posted December 30, 2018 On 12/29/2018 at 12:11 AM, Ej2itR said: I have only bought my car so didnt get time to check it over a pit. If you have use of a pit it is easy check. Have someone sit in the car started brakes one and in gear have them 'pop' the clutch so as to move engine you should be able to see or hear it. This has worked for me with other cars. Sent from my SM-A520F using Tapatalk Yeah, it would be nice to have a 'pit' or a 'four poster' but sadly it's just me with a trolley jack Quote Link to comment Share on other sites More sharing options...
