Allytat2504 Posted January 1, 2019 Share Posted January 1, 2019 Hello, Ordered some Autobeam ''LED Ambient Ring 3'' for my Ford Fiesta Mk7.5. Autobeam suggest wiring them straight into the battery and turning them on and off manually upon start up of the car and when stopping the car using the bluetooth app. I was wondering if it would be safe to wire them into the DRL, I don't have much knowledge of electrics I know how to wire in the lights and properly seal the wires, I just don't know if it will be safe with how much power the halos might take from the DRL. Any feedback would be helpful. https://autobeam.co.uk/collections/fiesta-mk7-5-2013-2017/products/ambient-ring3 Cheers! Alex Quote Link to comment Share on other sites More sharing options...
Lebadoo Posted January 9, 2019 Share Posted January 9, 2019 They're LED so the shouldn't pull much power. If you're handy with a multimeter you can temporarily connect them to the battery and measure their current draw in amps. You should be able to measure the current draw of the DRLs too. (Make sure to switch so the DRLs are at their brightest). Add these two numbers together and you should get the fuse rating you need. Quote Link to comment Share on other sites More sharing options...
Denbighite Posted January 9, 2019 Share Posted January 9, 2019 Hi. Could anybody tell me what tags mean after you've put in your title when starting a new topic please. Im new to this and it's a required field before I can write my question Quote Link to comment Share on other sites More sharing options...
Craigystline140+ Posted August 16, 2020 Share Posted August 16, 2020 Hi what size rings did you buy for your mk7.5 St-Line 1.0 Ecoboost please ? Quote Link to comment Share on other sites More sharing options...
