WES180 Posted January 5, 2019 Share Posted January 5, 2019 5 minutes ago, 1979Damian said: I take it yours has to be one of those super duper "stop start" batteries that lasts about 3 years? Yep, stop/start. I'm quite sure it's still the original battery though so not doing too bad on a 12 plate. Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted January 5, 2019 Share Posted January 5, 2019 Just now, WES180 said: Yep, stop/start. I'm quite sure it's still the original battery though so not doing too bad. If it's the original then you're doing very well I'd say (for any EFB battery), all that stop/start business really can give the battery a good hiding. 1 Quote Link to comment Share on other sites More sharing options...
Pebbleheed Posted January 5, 2019 Author Share Posted January 5, 2019 I’m home! At last. And warm again. The recovery guy tried jumper leads but it made no odds. He reckons it’s a starter motor issue too but he was surprised for a 3 year old car to have a faulty starter motor. Is it worth me testing the battery first or just taking it to ford and asking them to sort it under warranty with a potential faulty starter motor? I got a tow and did a bump start. It started in seconds that way. No issue. Ran fine all the way back. When I got home I turned off the engine and tried to start it again. Just a single click. Nothing else. When the car first stopped working it was silent except for a slight whir. I tried the foot out of the door trick and rocked it back and forward. The car did the single click noise after that - before the jump start attempt - so perhaps it is a faulty starter motor? 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 5, 2019 Share Posted January 5, 2019 So The codes mean nothing, that’s good. Get the bluefin back on once it’s sorted 😁 did the recovery guy clear the codes for you? id send it to the garage and let them sort it all under warranty 1 Quote Link to comment Share on other sites More sharing options...
Pebbleheed Posted January 5, 2019 Author Share Posted January 5, 2019 Yeah it drives a lot nicer with the bluefin. I’ll call my local dealer and get it booked in. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 5, 2019 Share Posted January 5, 2019 10 hours ago, Jonro2009 said: 11.6 is a little on the low side but not low enough to cause any problem at all. Any chance you can get the other key to the car? I thought like Damian that 11.6 was flat.....I'm presuming because it's an EFB the voltages are different? What's a fully charged voltage on an EFB, and what's flat? 9 hours ago, WES180 said: I nearly passed out when I looked how much a battery is for my Focus, not much change from £300! Where are you looking Wes? I just had a shock too at the cost, I might need a new EFB (the 700 one) and Eurocarparts had them for £126. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 5, 2019 Share Posted January 5, 2019 9 hours ago, 1979Damian said: If it's the original then you're doing very well I'd say (for any EFB battery), all that stop/start business really can give the battery a good hiding. I switch the start stop off, can't really be bothered with it. Wondering if that will help the battery last longer? Quote Link to comment Share on other sites More sharing options...
WES180 Posted January 5, 2019 Share Posted January 5, 2019 1 hour ago, Albert27 said: I thought like Damian that 11.6 was flat.....I'm presuming because it's an EFB the voltages are different? What's a fully charged voltage on an EFB, and what's flat? Where are you looking Wes? I just had a shock too at the cost, I might need a new EFB (the 700 one) and Eurocarparts had them for £126. Eurocarparts, put my reg in and they averaged about £275!!! 1 Quote Link to comment Share on other sites More sharing options...
Botus Posted January 5, 2019 Share Posted January 5, 2019 the starter not engaging on a slightly worn flywheel ring gear is dead common. put in second hand brake off rock the car 1 metre, neutral and see if it'll start. I think this needs to be engrained into any ford driver. you can try to jump with the mains it still won't make it turn could all the codes be generated by using blufin….. hence there existence since 5 months or when ever it was installed. batteries on modern stuff last 4 to 5 years 1 Quote Link to comment Share on other sites More sharing options...
Pebbleheed Posted January 5, 2019 Author Share Posted January 5, 2019 1 minute ago, Botus said: the starter not engaging on a slightly worn flywheel ring gear is dead common. put in second hand brake off rock the car 1 metre, neutral and see if it'll start. I think this needs to be engrained into any ford driver. you can try to jump with the mains it still won't make it turn could all the codes be generated by using blufin….. hence there existence since 5 months or when ever it was installed. batteries on modern stuff last 4 to 5 years I drove it home last night and tried to start it again then. It wouldn’t have it. Would the above still be worth trying if it’s been driven? Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 5, 2019 Share Posted January 5, 2019 43 minutes ago, WES180 said: Eurocarparts, put my reg in and they averaged about £275!!! Sale at the moment using code ‘SALE90’ battery for my 2017 Focus 1.5tdci with s/s = £157 1 Quote Link to comment Share on other sites More sharing options...
Botus Posted January 5, 2019 Share Posted January 5, 2019 18 minutes ago, Pebbleheed said: I drove it home last night and tried to start it again then. It wouldn’t have it. Would the above still be worth trying if it’s been driven? the ring gear bit seem to be OK for a while, once you can get it cranking (I guess) any burrs that caused it tend to get removed once you get it to crank. a mate at work had it 3 times over 18 months, the one I use has done it once. I tried a jump pack that wouldn't do a thing, rocked the car been good as gold for 2 years you may have other issues, trouble is at the temps we've got in the winter and sitting at the side of the road running diagnostics and scratching your head for 20 minutes would kill the battery very quickly untill you introduce a new issue 1 1 Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 5, 2019 Share Posted January 5, 2019 59 minutes ago, WES180 said: Eurocarparts, put my reg in and they averaged about £275!!! Yikes, was that with a discount code? If so, you must have a different battery to mine! Quote Link to comment Share on other sites More sharing options...
WES180 Posted January 5, 2019 Share Posted January 5, 2019 4 minutes ago, Albert27 said: Yikes, was that with a discount code? If so, you must have a different battery to mine! £167 with that discount code! I had looked over Christmas and hadn't seen that offer. I don't actually need one yet, I was just looking what they cost after my mate paid £90 fitted for one for my old Cmax he bought off me. Quote Link to comment Share on other sites More sharing options...
Albert27 Posted January 5, 2019 Share Posted January 5, 2019 2 minutes ago, WES180 said: £167 with that discount code! I had looked over Christmas and hadn't seen that offer. I don't actually need one yet, I was just looking what they cost after my mate paid £90 fitted for one for my old Cmax he bought off me. Sounds a bit better! ECP always have an offer on, don't ever pay full price. 9/10 Carparts4less (same company) are cheaper again with their discount code, the only annoying thing with them is returning parts as no branches. Quote Link to comment Share on other sites More sharing options...
andypsp Posted January 5, 2019 Share Posted January 5, 2019 5 hours ago, WES180 said: Eurocarparts, put my reg in and they averaged about £275!!! use code batt50 on eurocarparts and grab this for £140 😉 half price for exide batts only. Exide battery (EFB 110 Car battery (EL752) - 3 year Guarantee) 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 5, 2019 Share Posted January 5, 2019 56 minutes ago, andypsp said: use code batt50 on eurocarparts and grab this for £140 😉 half price for exide batts only. Exide Battery (EFB 110 Car Battery (EL752) - 3 year Guarantee) Only available on Exide ‘premium’ batteries, which are not suitable for many cars ☹️ 45% off using ‘sale90’ though Quote Link to comment Share on other sites More sharing options...
andypsp Posted January 5, 2019 Share Posted January 5, 2019 46 minutes ago, Jonro2009 said: Only available on Exide ‘premium’ batteries, which are not suitable for many cars ☹️ 45% off using ‘sale90’ though i have it working on all exide batts did you try the code 😉 Exide battery (Excell battery 075 3 Year Guarantee)Product Code : 444770750 Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 5, 2019 Share Posted January 5, 2019 7 hours ago, Jonro2009 said: Sale at the moment using code ‘SALE90’ battery for my 2017 Focus 1.5tdci with s/s = £157 There's never a sale, they are a bunch off rip of merchants that everyone thinks is great lol. 3 Quote Link to comment Share on other sites More sharing options...
martyntdci Posted January 5, 2019 Share Posted January 5, 2019 7 hours ago, Jonro2009 said: Sale at the moment using code ‘SALE90’ battery for my 2017 Focus 1.5tdci with s/s = £157 try end35 at euro Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 5, 2019 Share Posted January 5, 2019 57 minutes ago, andypsp said: i have it working on all exide batts did you try the code 😉 Exide Battery (Excell Battery 075 3 Year Guarantee)Product Code : 444770750 Can you screenshot that working for you because it doesn’t work for me and it specifically says that BAT50 only works on premium batteries in the Exide range. 14 minutes ago, stef123 said: There's never a sale, they are a bunch off rip of merchants that everyone thinks is great lol. The list price for the battery I require is £279 and if I use the code ‘SALE90’ then it drops to £157 - is that the price they are elsewhere and ECP just over inflate their prices then discount them at the checkout? Quote Link to comment Share on other sites More sharing options...
Bwlmog Posted January 5, 2019 Share Posted January 5, 2019 Eurocarparts, put my reg in and they averaged about £275!!!Just checked for the Mondeo I was looking to buy and it’s exactly the same. Crazy money, I currently have a Hyundai Santa Fe which is a huge car and the battery for that is around £140.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 5, 2019 Share Posted January 5, 2019 7 minutes ago, Jonro2009 said: Can you screenshot that working for you because it doesn’t work for me and it specifically says that BAT50 only works on premium batteries in the Exide range. The list price for the battery I require is £279 and if I use the code ‘SALE90’ then it drops to £157 - is that the price they are elsewhere and ECP just over inflate their prices then discount them at the checkout? Correct. I buy parts usually a couple of times a week. I’ve hardly any interest in ecp now. My local factors can wipe the floor with them for same or better brands. 2 Quote Link to comment Share on other sites More sharing options...
andypsp Posted January 5, 2019 Share Posted January 5, 2019 34 minutes ago, Jonro2009 said: Can you screenshot that working for you because it doesn’t work for me and it specifically says that BAT50 only works on premium batteries in the Exide range. The list price for the battery I require is £279 and if I use the code ‘SALE90’ then it drops to £157 - is that the price they are elsewhere and ECP just over inflate their prices then discount them at the checkout? My Basket - 1 item(s) Continue shoppinProceed To Checkout Items Unit Price Quantity Total Price Delivery Options Exide Excell Battery 063 3 Year GuaranteeProduct Code : 444770630 £82.99 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Delete £82.99 UK Delivery More infoClick & Collect from Check stock at your local storeInternational Delivery available Discount Code REMOVE CODE Your Discount has been applied: ( 50% Off Selected Batteries ) Subtotal: £82.99Discount: - £41.50Total (inc VAT): £41.49 1 Quote Link to comment Share on other sites More sharing options...
andypsp Posted January 5, 2019 Share Posted January 5, 2019 now this is hot the batt50 code for euro car parts will work with all makes/brands of batts on the website Quote Link to comment Share on other sites More sharing options...
