Focus2k6 Posted January 5, 2019 Share Posted January 5, 2019 Hi, sorry if this is posted in wrong place. I have ford focus petrol 2006 1.6 ghia, when my car is stationary for 10-15 mins the gauge will increase to optimum tempreature (about 88° and stays there) but when I travel around in the car the temp drops slowly but surely back down to flat as though it is reading cold. Any ideas would be great thank you Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted January 5, 2019 Share Posted January 5, 2019 Sounds like the thermostat is stuck open. Are you noticing that the car takes ages to warm up? Quote Link to comment Share on other sites More sharing options...
Focus2k6 Posted January 5, 2019 Author Share Posted January 5, 2019 Hi, thanks for reply It does take a while to feel warm air coming In from fans inside the car and I did notice after driving for like 40mins that when I put the heaters on full it was just warm air not hot Also I can go for a 30 mile drive and the temp gauge won't budge (stays cold) except for very small movements if I am at lights for a bit. then if I pull up after a good drive for say 15 mins the tempreature goes to normal and stays like that if I don't move, but as soon as I drive off and at a steady speed it will slowly drop to cold(60°) I had my engine running in a car park the other day and I got the car up to normal temp and I drove round the car park slowly (didn't go past 10mph) for about half an hour and the temp stayed bang on normal (88°) and then as I was driving home it slowly dropped down except for the pauses at red lights It's effecting the efficency of the car aswell it's running at 21MPG Cheers. Si. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted January 5, 2019 Share Posted January 5, 2019 Yes that definitely sounds like a stuck open (or at least partially stuck open) thermostat. Cheap and easy enough to replace. 1 Quote Link to comment Share on other sites More sharing options...
Focus2k6 Posted January 5, 2019 Author Share Posted January 5, 2019 Excellent I will sort a new one out and post back results thanks very much for your help Quote Link to comment Share on other sites More sharing options...
CrazyInWeston Posted January 12, 2019 Share Posted January 12, 2019 On 1/5/2019 at 4:22 PM, Focus2k6 said: It's effecting the efficency of the car aswell it's running at 21MPG WTF? I've owned my 2005 1.6 Ti-VCT coming up to 18 months now, and my car has the exact same problem, engine never warms up, unless in stop/start where it'll reach optimum and stay there, just like yours.... But I've never had mine at 21MPG, That is bad, lowest I've had was 27mpg but I did have kinda the wrong oil in it at that time, my current Winter MPG EVEN WITH TWO TYRES that have a slow leak and being slowly deflated and I only inflate them weekly, 32MPG, my summer 34/35MPG. Thing is right, I am astonished as you are, I rev the beans off my engine, dont change gear till 4000RPM at least, even in 1st - keeping it in 4th gear well past 30mph (because we all know we can put it in 5th here) AND the most surprising of all, hover around 90mph on the Motorway, my MPG just climbs even higher - I really do not understand it. Edit: Another thing, my car uses up no oil whatsoever! Despite the high revs, speed etc, I last checked it last Monday, and the oil level was excatly the same as it was 14 months ago!!! (Havent so far been able to afford the annual service) Quote Link to comment Share on other sites More sharing options...
Botus Posted January 12, 2019 Share Posted January 12, 2019 tractors with slow warm up may be a result of the EGR being tampered with on vvti petrol's some car's had an electrically heated thermostat that works in conjunction with engine management (costs a fortune £110) when the heater element pops it runs hot and the fan runs almost continuously others got a conventional one and they are £30 - its quite common for a stat to wear out on lots of cars Quote Link to comment Share on other sites More sharing options...
