Ryan1985
2007 1.8 tdci fuel pump.
Hi guys, can any one point me in to the direction of a how to guide to replace a high pressure fuel pump on this engine.
The engine is timed up and cam belt off, need to see how to remove the pump?
Haynes has a page and a bit, with photos, on replacing this pump. I have not put it to the test, and Haynes is far from perfect on modern cars, but it looks to be a good start. If you already have the belt off, then I don't think there any major difficulties, except one: The huge importance of extreme cleanliness when dealing with any of the high pressure fuel pipes, or the fuel pipe into the pump. Invisible bits of swarf & dirt will easily wreck both the pump and the injectors.
Ford technicians use a mini vacuum cleaner I believe.
If you do not already have it, Haynes would be a worthwhile investment for such a critical and potentially expensive job. If urgent, it looks like if you order a manual from the website, you get access to an on-line version immediately.
  Only 75 emoji are allowed.
