Philbry69 Posted January 31, 2019 Share Posted January 31, 2019 Can anyone advise what to do to update my sat nav on Sync2. The Ford website doesn't seem to allow me to purchase the updatre as link is no longer available. How can i purchase a new SD card etc. Ford Focus 2015. Thanks. Quote Link to comment Share on other sites More sharing options...
Sohrab Focus 1.0 100 bhp Posted January 31, 2019 Share Posted January 31, 2019 Hi, you will need to ring ford direct for this or you can purchase an SD card with the new maps from eBay 1 Quote Link to comment Share on other sites More sharing options...
TitXlover Posted January 31, 2019 Share Posted January 31, 2019 Have had a couple from eBay, no problems with either. £20 upwards. Ford will change a lot more.Sent from my SM-T713 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
TitXlover Posted January 31, 2019 Share Posted January 31, 2019 F7 is the latest map card.Sent from my SM-T713 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 31, 2019 Share Posted January 31, 2019 Do they release different versions for Sync2 and 3? Sync3 is currently F8 Quote Link to comment Share on other sites More sharing options...
TitXlover Posted January 31, 2019 Share Posted January 31, 2019 Sync3 I think can be downloaded. Sync2 is sd card based.They normally update in March, so f8 May be due soon.Sent from my SM-T713 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jonro2009 Posted January 31, 2019 Share Posted January 31, 2019 2 minutes ago, TitXlover said: Sync3 I think can be downloaded. Sync2 is sd card based. They normally update in March, so f8 May be due soon. Sent from my SM-T713 using Tapatalk F8 currently available on Sync3 1 Quote Link to comment Share on other sites More sharing options...
Philbry69 Posted January 31, 2019 Author Share Posted January 31, 2019 Thank you all for your comments. I will try Ford Direct then as heard eBay ones are not always the best. Quote Link to comment Share on other sites More sharing options...
angusstewart Posted October 5, 2019 Share Posted October 5, 2019 Bought a used 2015 Mondeo, SD card labeled F8 was out of date. Dealer provided an up-to-date card labeled F3, I also obtained a 2020 card from amazon, labeled F8... Looking at the files on my PC there was no way to tell when the files were created - text file dates made no sense (dated 2012 &c!). What do those F numbers mean? Part numbers can be identical regardless of age of the files! Quote Link to comment Share on other sites More sharing options...
Carpman Posted February 18, 2020 Share Posted February 18, 2020 Evening all. I've got sync 2 on a December 2015 focus titanium. The sat nav part continues to try and send me down a very main A road (A14) that part of is shut for 2 years !! Even when I continue past the closed road the sat nav still tries to get me to do a U turn and go back to the closed part. Surely it should recalculate route shouldn't it ??Otherwise it's just a road atlas on an sd card. Cheers Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted February 19, 2020 Share Posted February 19, 2020 17 hours ago, Carpman said: Evening all. I've got sync 2 on a December 2015 focus titanium. The sat nav part continues to try and send me down a very main A road (A14) that part of is shut for 2 years !! Even when I continue past the closed road the sat nav still tries to get me to do a U turn and go back to the closed part. Surely it should recalculate route shouldn't it ??Otherwise it's just a road atlas on an sd card. Cheers If it thinks the road is open then it will keep trying to route you back down the road until you're far enough away from it that an alternative route is quicker. A sat nav is only as good as the mapping data it's been fed. Quote Link to comment Share on other sites More sharing options...
