nashdm2 Posted February 1, 2019 Share Posted February 1, 2019 Guys, about to get a Mk8 Vignale. Want to install some LED Bulbs for the fog lights/cornering lights. Before I start pulling things apart, has anybody removed the covers on a MK8 Vignale yet please? Thanks, Dave 1 Quote Link to comment Share on other sites More sharing options...
jsk Posted February 2, 2019 Share Posted February 2, 2019 Try this website its for the ST but i think the Vignale has the same fog light set up. think 1 Quote Link to comment Share on other sites More sharing options...
nashdm2 Posted February 2, 2019 Author Share Posted February 2, 2019 Hi jsk, thanks, watched this a couple of days ago, although the actual light is very similar to the ST, the surrounds are very different. If I break the cover itself whilst removing, not a problem, but, if I break the bumper then that is very different. There is a possibility that I can get to it from behind, but, need to check when it arrives. Quote Link to comment Share on other sites More sharing options...
BJT Posted February 4, 2019 Share Posted February 4, 2019 The best place to go is in the wheel arch behind where the fog lights are positioned. There will be 3 screws undo them and then pull the wheel arch cover you’ll be able to see the fog light bulb then you can replace them. Quote Link to comment Share on other sites More sharing options...
nashdm2 Posted February 4, 2019 Author Share Posted February 4, 2019 Thanks, I will have a go when it arrives, I am sure the brochure will detail how it is done. Quote Link to comment Share on other sites More sharing options...
nashdm2 Posted February 4, 2019 Author Share Posted February 4, 2019 Just had a look at the online owners manual, it says to unclip the outer cowling and then unscrew the lamp to get access behind, so, essentially the same as in the vid above. Quote Link to comment Share on other sites More sharing options...
Lorenzo0019 Posted September 27, 2019 Share Posted September 27, 2019 I have a Vignale aswell and I’ve tried to take off the cover but it’s super stiff and feel like I will scratch the body work. Have you found a way to do this Dave ? Quote Link to comment Share on other sites More sharing options...
Jollyandy Posted September 29, 2019 Share Posted September 29, 2019 If you start at the inner edge (number plate end) and gradually ease the cover out, you’ll find it comes out easily. A plastic trim remover helps too! Just remember if you’ve got front parking sensors then there’s one in the cover, so be careful not to stress the wiring that’s attached to it. When you replace it just line up the tongues on the cover with the appropriate hole, and press evenly until it’s back in place. I used Autobeam LED’s in mine, and the difference is amazing! Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Lorenzo0019 Posted October 8, 2019 Share Posted October 8, 2019 Thank you so much I’ll try it when I can 💯 Quote Link to comment Share on other sites More sharing options...
