BP2411 Posted February 9, 2019 Share Posted February 9, 2019 Hello everyone, just wondering what sort of mpg people are getting out of theirs? I only really use it for work & back (4 miles each way) and I get about 25 mpg! It's recently been really bad, not sure if it's due to the cold weather or the price of fuel or if something more sinister is to blame. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2019 Share Posted February 9, 2019 The price of fuel has no effect on miles per gallon. Just pence per mile. But it's dropped a bit recently anyway lol. With the high winds and short town journeys mine has been bad this week...I was sitting on 35mpg after half an hour yesterday. 😮 Fortunately the tank average is still above 50mpg but I do one longer journey a week which makes up for the short ones. That said, 25mpg from a 1.4 TDCi sounds absolutely horrific, I've had 20 year old, 2.0 petrols doing better MPG than that lol. Have you got access to Forscan to check for any faults? Are any of the brakes binding? Has the EGR been blanked? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted February 9, 2019 Share Posted February 9, 2019 That does seem very low I get more than that in an ST, have you looked at having de-carbonised? Using something like Terraclean Quote Link to comment Share on other sites More sharing options...
iantt Posted February 9, 2019 Share Posted February 9, 2019 25mpg!! Last time I was getting that was in a 320hp Mazda 3 MPs. Tdci is not exactly the best vehicle to go 4 miles each way in. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 I do have forscan, I'll scan later no breaks binding Egr isn't blanked but was removed & cleaned recently, glow plugs were also changed recently I haven't looked into de-carbonising yet but due to the mileage (175k) I think it's due is there something I can do myself first like redex (but not so controversial lol) Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2019 Share Posted February 9, 2019 I would not risk a carbon clean on a 175k DV4 lol. There are more expensive Redex type additives, Millers or Archoil for example, but tbh they're unlikely to give you the 20mpg that you've lost somewhere. I'd be checking for injector leaks next. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 I had the seals changed on the injectors within the last 18 months - 2 years and I do very little mileage so I'd be fuming if it was them again but something is definitely wrong. What's my best option for something I can add to the tank to get any gain in mpg? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2019 Share Posted February 9, 2019 1 minute ago, BP2411 said: I had the seals changed on the injectors within the last 18 months - 2 years and I do very little mileage so I'd be fuming if it was them again but something is definitely wrong. What's my best option for something I can add to the tank to get any gain in mpg? In my experience I haven't found any additives to increase MPG noticeably so don't bother any more. Do you get any black exhaust smoke that might indicate a boost leak? It may even be the injectors themselves at fault, especially if they're still original and not been refurbed with that mileage? Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 No signs of any problems bar shocking acceleration but it's been like that since I bought it. I've had the car 3 years in May and I haven't had the injectors changed in that time, not sure if any of the previous owners did it though. oil & filter were changed May 2018, cabin & air filter haven't been changed since May 2016, if the air filter could be a suspect? Quote Link to comment Share on other sites More sharing options...
iantt Posted February 9, 2019 Share Posted February 9, 2019 When was the fuel filter last changed? Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 I've never changed it but after the nightmare I had trying to start the car after I had to remove it to clean the egr I'd rather burn the car than change it lol Quote Link to comment Share on other sites More sharing options...
iantt Posted February 9, 2019 Share Posted February 9, 2019 Perhaps you need to buy some petrol then instead of diesel. 1 Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 When I removed it to clean the egr valve I had to lend a syphon pump to get it started again (3 days later) as ford decided not to put the hand primer on the MK7 for some reason. Quote Link to comment Share on other sites More sharing options...
iantt Posted February 9, 2019 Share Posted February 9, 2019 It's easy enough if you have a primer to hand.what your issue was due to the time left removed, the fuel in the lines flowed back into the tank . Alot of air to draw out using a Syphon pump. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 9, 2019 Author Share Posted February 9, 2019 I've seen people do it with a brake bleeding kit, do you have a link to a primer? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9, 2019 Share Posted February 9, 2019 There are thousands on eBay - https://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_sop=15&_nkw=diesel hand primer&rt=nc&LH_PrefLoc=1&_trksid=p2045573.m1684 Or head to the scrap yard and get one from an older Fiesta/Peugeot/Citroen. 1 1 Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 10, 2019 Author Share Posted February 10, 2019 No faults found with forscan, would injectors or fuel filter show on forscan though? I'll go for the filter first due to the mileage and the fact I've never changed it . Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 10, 2019 Share Posted February 10, 2019 They may not show codes, but you can use Forscans live data readings to determine the condition of both. Fuel filter is definitely worth doing if it's not been done though. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 10, 2019 Author Share Posted February 10, 2019 Is there a guide on how to check live data? What sort of ranges am I looking for? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 10, 2019 Share Posted February 10, 2019 There's loads of live data available on Forscan, it's all very intuitive though so just have a go. The main ones to check here are requested fuel pressure against actual fuel pressure. If there's a big discrepancy, particularly at higher rpm, then the filter may be restricting flow. The other one is injector corrections, they should be roughly the same across all 4, if one or two are very different then it's worth doing a physical leak off test (YouTube that one) to confirm injector wear. 1 1 Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 14, 2019 Author Share Posted February 14, 2019 Had another go on forscan the other day but couldn't see how to get requested fuel pressure vs actual fuel pressure or the injector corrections. Fuel filter is definitely on the to do list but I wanted to check it before & after to see any improvements. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted February 14, 2019 Author Share Posted February 14, 2019 Found this on another site, hopefully it's right to test injectors, then I'll just need to find out how to see actual Vs requested fuel pressure. 1. Run & connect, go to Dashboard section 2. Double click on a dashboard or press Setup button, PIDS selection dialog will be opened. Select ICU module. Select PIDs CYL1_RATIO, CYL2_RATIO, CYL3_RATIO, CYL4_RATIO and click OK. 3. Run the engine, wait until engine speed is stabilized at idle. 4. Click Start button and monitor Quote Link to comment Share on other sites More sharing options...
BP2411 Posted March 1, 2019 Author Share Posted March 1, 2019 Finally changed the fuel filter & now I have a load of errors P0089 fuel pressure regulator performance P2138 throttle / pedal position sensor / switch d/e voltage correlation U0401 invalid data received from ECM/pcm P1201 cylinder 1 injector circuit open / shorted P1202 cylinder 2 injector circuit open / shorted It's too dark to mess around anymore tonight, I've cleared the codes they come straight back, it was running fine before I put the air filter back in so hopefully that's what's causing the injector problem. Quote Link to comment Share on other sites More sharing options...
weebl Posted March 1, 2019 Share Posted March 1, 2019 On 2/9/2019 at 8:40 AM, BP2411 said: I only really use it for work & back (4 miles each way) and I get about 25 mpg! To be fair, any car, but especially a diesel is not going to do too well on a 4 mile journey. This time of year will also make it worse. I find my car takes a good 5 miles or so just to get the coolant temp stable, that on the motorway. Taking it for a good drive should see your MPG increase. Quote Link to comment Share on other sites More sharing options...
BP2411 Posted March 1, 2019 Author Share Posted March 1, 2019 It's not going anywhere at the moment lol I'm praying I've trapped a wire while rushing to get the air filter on by torch light. Quote Link to comment Share on other sites More sharing options...
