Chris Hudson Posted February 22, 2019 Share Posted February 22, 2019 I have 2011, 2L Titanium. Spotless car apart from a gap that has appeared on the plastic edging on the cill. Looks like its came unstuck as it's not damaged. Anyone used a sealant/adhesive to stick it back ? Quote Link to comment Share on other sites More sharing options...
dezwez Posted February 22, 2019 Share Posted February 22, 2019 adhesive should be fine to put it back聽馃檪 Quote Link to comment Share on other sites More sharing options...
Lenny Posted February 22, 2019 Share Posted February 22, 2019 1 hour ago, dezwez said: adhesive should be fine to put it back聽馃檪 Tec7 Just don't close the door until it's dry 馃槀 Quote Link to comment Share on other sites More sharing options...
Chris Hudson Posted February 22, 2019 Author Share Posted February 22, 2019 I guessed adhesive would be fine .........but which ? For clarity the cill protective moulding is the one at the bottom of the cill which follows through to the lower part of the front wheel arch. Thanks for responses so far ......................... 1 Quote Link to comment Share on other sites More sharing options...
Chris Hudson Posted April 21, 2019 Author Share Posted April 21, 2019 Tiger Seal did the trick !聽 Tried 2 x types super glue initially without success. When using Tiger Seal be sure to use masking tape to give an unnoticeable repair. 1 Quote Link to comment Share on other sites More sharing options...
