Goldilocks Posted February 24, 2019 Share Posted February 24, 2019 I am not very technical with respect to cars and so please bear with me. How do I set the imobiliser on my Ford Titanium 2014 plate? Once I have double pressed the electronic key fob and the lights on the car flash is that it is the car imobilised? Does the imobiliser disengage the engine if someone tries to break into the vehicle - How does it work in simple terms? Thank you in advance for any helpful well meaning replies. Quote Link to comment Share on other sites More sharing options...
Goldilocks Posted February 24, 2019 Author Share Posted February 24, 2019 Edit:- Does the imobiliser disengage the engine if someone tries to break into the vehicle or just set off an alarm - How does it work in simple terms? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 24, 2019 Share Posted February 24, 2019 The immobiliser is active all the time regardless of the car being locked or unlocked. It is only deactivated when the correct key fob is placed in the ignition barrel.* The immobiliser simply stops the engine from being started without the correct key fob present. *If you have a keyless ignition, the immobiliser is deactivated by the kryfob being inside the car. However, modern thieves are able to bypass this without too much difficulty which is why keyless cars are being targeted by thieves recently. 1 1 Quote Link to comment Share on other sites More sharing options...
Goldilocks Posted February 24, 2019 Author Share Posted February 24, 2019 I appreciate your reponse TomsFocus - Thank you. When I press my key fob to lock the car and the lights flash a couple of times is that alarming the car in some other way and is it different from the imobiliser? Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted February 24, 2019 Share Posted February 24, 2019 2 minutes ago, Goldilocks said: When I press my key fob to lock the car and the lights flash a couple of times is that alarming the car in some other way and is it different from the imobiliser? The double flash is just the door locks moving to a position that can not be unlocked manually from inside the car. So even with a window broken, it will still not be possible to open the door without a key. The immobiliser is built into the ECU and other electronic modules, and is almost entirely separate. It stops the engine from being started without a valid key that contains the correctly coded immobilser part. It should activate a few seconds after removing the ignition key, or after taking the keyless "key" away from the vehicle. So the locks, alarm and remote control help prevent stuff being nicked from the car, though only if the car is in a public place. The immobiliser prevents the car from being driven away by a thief. But they could easily steal the car if they had a breakdown truck or car trailer. No security measures are perfect! 1 1 Quote Link to comment Share on other sites More sharing options...
Goldilocks Posted February 25, 2019 Author Share Posted February 25, 2019 That makes it all clear to me - Thank you. Quote Link to comment Share on other sites More sharing options...
