KayakJon Posted February 26, 2019 Share Posted February 26, 2019 Why has the new heater resistor that I struggled to fit, blown after two days us? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 26, 2019 Share Posted February 26, 2019 Either the fan is worn and drawing too much power, or it was a cheap aftermarket resistor? Quote Link to comment Share on other sites More sharing options...
KayakJon Posted February 28, 2019 Author Share Posted February 28, 2019 Thanks. I think the fan is on its way out. Quote Link to comment Share on other sites More sharing options...
isetta Posted March 5, 2019 Share Posted March 5, 2019 on my focus the resistor pack blew again quickly because the fan was stiff as water had got into a bearing. So the extra power needed for the fan was overloading it. I cleaned and oiled the fan bearings and it was fine after that. Both times it blew I did not replace the whole resistor pack, the resistors were fine, it was the thermal fuse both times. The thermal fuse is part of the resistor pack but a new one can be soldered on after buying from eBay for little money. I also fixed the cause of water getting in there. You might not need a new fan, you might just need to dismantle it and give it some care and maintenance. Quote Link to comment Share on other sites More sharing options...
KayakJon Posted March 12, 2019 Author Share Posted March 12, 2019 Thanks. I’ve just got another fan for a good price. Also bought another resistor. Just got the lovely job of fitting it all back together. Quote Link to comment Share on other sites More sharing options...
