Focus cmax 54 reg , starting prnlems
Hi ive got a 2.0 tdci focus cmax , its not starting the trouble codes ive got are p0380-78 glowplug control circuit , and p0341-78 camshaft position sensor , ive tried anew sensor still the same , ive had a multimeter on the 3 wires and have 1 with 0 volts , 1 with 10.5 volts and 1 with 0.07 volts , after looking around im thinking the 0.07 volts wire is the signal wire and should be more around 5volts ? Not 100 percent if im correct . But was thinking is there a break in the wire ? Where do the wires goto to check the wires . Any help would be appreciated many thanks
  • 1 year later...
Did you get a resolution to your problem
