George. 1991 Posted March 16, 2019 Share Posted March 16, 2019 Hello to you all. I need some advice on replacing a cam belt on a 2006 Focus. Can anyone help me with some useful solutions...? George. Quote Link to comment Share on other sites More sharing options...
WES180 Posted March 16, 2019 Share Posted March 16, 2019 Can it really be that easy? Quote Link to comment Share on other sites More sharing options...
George. 1991 Posted March 16, 2019 Author Share Posted March 16, 2019 Did I hear a baby crying in the back ground towards the end of that video clip!? Anyways, nice trick. Quote Link to comment Share on other sites More sharing options...
WES180 Posted March 16, 2019 Share Posted March 16, 2019 18 minutes ago, George. 1991 said: Did I hear a baby crying in the back ground towards the end of that video clip!? Anyways, nice trick. Ha, yeah, I think someone has recorded their tv and posted the clip. Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 16, 2019 Share Posted March 16, 2019 Ask him about changing the tensioner or guide/deflection pulleys. A trick of use to absolutely no one who intends on doing the job properly. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 17, 2019 Share Posted March 17, 2019 11 hours ago, stef123 said: Ask him about changing the tensioner or guide/deflection pulleys. A trick of use to absolutely no one who intends on doing the job properly. Tbf he did change the tensioner on that programme...held the belt under tension with a cable tie while swapping them over. It was actually a pretty good idea but has now spread across the forums with lots of people thinking they can just swap a cambelt in 30 seconds. It also won't work on a lot of cars because of the lip on the crank pulley lol. 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted March 17, 2019 Share Posted March 17, 2019 17 hours ago, George. 1991 said: Hello to you all. I need some advice on replacing a cam belt on a 2006 Focus. Can anyone help me with some useful solutions...? George. I say if you are unsure get it done professionally you can damage your engine if not done right 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 17, 2019 Share Posted March 17, 2019 10 hours ago, TomsFocus said: Tbf he did change the tensioner on that programme...held the belt under tension with a cable tie while swapping them over. It was actually a pretty good idea but has now spread across the forums with lots of people thinking they can just swap a cambelt in 30 seconds. It also won't work on a lot of cars because of the lip on the crank pulley lol. I can think of several engines where the crank pulley needs removing to remove the timing belt lower cover. Anyone who follows his idea deserves to get burned. Taking shortcuts with a timing belt 😩 Quote Link to comment Share on other sites More sharing options...
Tekman Posted March 17, 2019 Share Posted March 17, 2019 Hi Mate I can tell you from experience that the 1.6 has a floating crank pulley and does have to come off to change belt. you do need the correct pin that you take a bolt out of bottom of engine and screw it in to set bottom end and locking bar for cams. get yourself a timing locking kit before starting also the crank bolt can be very very tight and you sometimes require a impact air gun to get it off. however you can do it yourself at home but if you not sure get garage to do it costly if you mess up Cheers Alan 1 Quote Link to comment Share on other sites More sharing options...
George. 1991 Posted March 19, 2019 Author Share Posted March 19, 2019 Hi Alan. At the moment in time I'm currently waiting for a quote on how much it will cost me to get it done at a garage...? My Dad had recently had a cam belt changed on his 2008 Mondeo and paid £500.00 to get it done! I was like What!? lol Quote Link to comment Share on other sites More sharing options...
Tekman Posted March 19, 2019 Share Posted March 19, 2019 Hi George Wow that`s high did he have chrome pulleys and chrome water pump fitted lol Cheers Alan Quote Link to comment Share on other sites More sharing options...
eddie eastwood Posted March 19, 2019 Share Posted March 19, 2019 Hi George When I had mine changed 3 years ago at my local independent garage, that I have used for 15 years, the cost then was £291.95. That consisted of 3 hours labour, the timing belt kit, new water pump, auxiliary and air con belts. and anti freeze. Quote Link to comment Share on other sites More sharing options...
George. 1991 Posted March 25, 2019 Author Share Posted March 25, 2019 Hi Alan. Don't know because I wasn't with him at the time since he had it done at his brother's Garage up in York. George. Quote Link to comment Share on other sites More sharing options...
George. 1991 Posted March 25, 2019 Author Share Posted March 25, 2019 Hi Guys Managed to get a quote from TC Harrison Ford Centre Derby today for a Cambelt + water pump at £439.00 & I have just booked my car in for tomorrow to have it all done by via Professionals, so Happy days. 1 Quote Link to comment Share on other sites More sharing options...
