Rear Quarter Window seals
ajf_1986
Hi guys,
New to the forum but used a lot of your info in the past to fix things up on my 2013 Mk3 Focus.
The seals on both rear quarter windows has worn and ripped. This is causing a bit of water coming in and collecting in the side cup holders. Do you know if there is a way to just replace the seals or is it a case of getting a new window put in on with the seal already attached. I have seen it looks like a bit of a ball ache to try and remove the window so would I be best getting a garde to sort if for me?
Thanks in advance.
Alex
8 minutes ago, ajf_1986 said:
Hi guys,
Thanks in advance.
Alex
Not seen that one before, usually rear quarter glass is secured using a specialist adhesive which isn't really designed to allow the glass unit to be removed.  If you can't find a way of repairing the seal I'd personally be leaning towards getting it replaced professionally otherwise you could end up with an even bigger leak.
can it be done with a load of bathroom sealant?
  • 1 year later...
On 3/18/2019 at 10:51 AM, ajf_1986 said:
Hi guys,
Thanks in advance.
Alex
Hello did you manage to resolve this issue - we’ve got the same problem with ours
Can't help feeling if that was my car, I'd be heading to AutoGlass to fix. Even main dealers farm that kind of stuff out to glass professionals... and welcome to the forum.
  • 2 months later...
Ours is exactly the same on a c-max as the window isn't damaged auto glass quoted me £340 to repair. Wtf.
  • Confused 1
