Solverz Posted March 28, 2019 Share Posted March 28, 2019 Hi Guys, Im wondering if you guys could help, (newbie here) I am just about to attempt to bleed my brake fluid but I read that I should also bleed the clutch as well? I can't find the slave cylinder to find the bleed valve, would you guys be able help me locate it 😅 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 28, 2019 Share Posted March 28, 2019 The slave cylinder is inside the gearbox so you can't see it. Look at the top of the gearbox,to the left of the shifting mechanism, and you should see the hard clutch pipe (looks like brake pipe) with a bleed nipple at the end. Quote Link to comment Share on other sites More sharing options...
Solverz Posted March 28, 2019 Author Share Posted March 28, 2019 -- Quote Link to comment Share on other sites More sharing options...
Solverz Posted March 28, 2019 Author Share Posted March 28, 2019 6 minutes ago, TomsFocus said: The slave cylinder is inside the gearbox so you can't see it. Look at the top of the gearbox,to the left of the shifting mechanism, and you should see the hard clutch pipe (looks like brake pipe) with a bleed nipple at the end. Oh I see, so the bleed valve for the clutch is on the side of the gearbox? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted March 28, 2019 Share Posted March 28, 2019 23 minutes ago, Solverz said: Oh I see, so the bleed valve for the clutch is on the side of the gearbox? I'd say more top than side but yeah, it'll be easy to spot when you're looking at it. 1 Quote Link to comment Share on other sites More sharing options...
Solverz Posted March 28, 2019 Author Share Posted March 28, 2019 51 minutes ago, TomsFocus said: I'd say more top than side but yeah, it'll be easy to spot when you're looking at it. Thanks buddy, I'll take another look :) Quote Link to comment Share on other sites More sharing options...
