Owen_1 Posted April 5, 2019 Share Posted April 5, 2019 Hello All, I have a 14 Plate Ford Fiesta Ecoboost 1l Petrol, that is in limp mode. I was driving one evening and it was fine, the next morning I woke up for work and the engine started up, but flashed up with the spanner symbol and notification of Engine Malfunction service Now. It was serviced just 4 months ago came back fine no issues. I've taken it to a garage and they have got the following error codes: P06A6 - Sensor referential voltage fault in circuit, P0558 - Brake Booster Pressure Sensor Signal Too High, P2135 - Throttle Valve/Pedal Faulty Signal, P1573 - Throttle Valve Signal Missing, P0106 - Air Pressure/Boost Pressure Sensor Faulty Signal, P0238 - Boost Pressure Sensor Signal Too High, P0234 - Boost Pressure intake Pipe Pressure Too High, P00CF - Boost Pressure Turbo Charger Faulty Signal. The Garage wasn't sure what was wrong with it and suggested booking it in with a Ford Specialist, they are looking at the car on 16th, but didn't know if I could check anything before then? Any help would be gratefully appreciated. Thanks, Owen Quote Link to comment Share on other sites More sharing options...
HH0319 Posted April 18, 2019 Share Posted April 18, 2019 Hi Owen , Sorry I'm unable to help but I too have recieved the spanner symbol with engine malfunction service now about 2 times however the car has never gone into Limp mode with me , What did the specialist say ? Quote Link to comment Share on other sites More sharing options...
