[Focus 2019 MK4] FORScan Programming - Add A/C to SYNC3
Hello,
I´m new to this forum and wanted to share the possibility to add A/C into SYNC3.
The videos are in german but they have automatic generated subtitles.
Video 1 - What is needed and how to safe configuration
Video 2 - How to activate A/C in SYNC3
I wanted to ask if someone is also modifying parameters here in the forum so we can built up a database together for this new model.
I have only found some Excel-Sheets for other types like F-150. The MK4 is too new. Maybe someone of you have some sources ?
Cheers
Forscan are working on updates to include Focus IV, autolocking works at present but you need the modified ELM327 over USB (the one with the switch) as the bluetooth ones won't talk to all the modules.
Keep an eye on Forscan for update releases
  • 3 months later...
GOOD...
The MK4 resource is so few.
I only open the autolock item.
