innovatetom Posted April 6, 2019 Share Posted April 6, 2019 Hi all I recently bought my 65 plate Fiesta black edition and noticed in the apps section of the display that an update is needed. Headed to ford website with my VIN, downloaded the update files and formatted a USB (3.0) stick to FAT32. Extracted the files, headed to car, car says update files not found. Am I doing something wrong? The version I seem to have downloaded is 5.8, I'm reading there is 5.9 and 5.11 available somewhere? Might the 3.0 device not be supported? Any help is very much appreciated, thanks Quote Link to comment Share on other sites More sharing options...
Zico Posted April 6, 2019 Share Posted April 6, 2019 I don't have the details to hand at the moment (but will find them). There were some issues with the filenames in the .LST files that needed to be sorted out as there was a typo with one or two names. The other issue that some people also had was that the update wouldn't work from a USB 3.0 stick. I got mine to work via a USB 2.0 stick. Quote Link to comment Share on other sites More sharing options...
Zico Posted April 6, 2019 Share Posted April 6, 2019 I've re-uploaded the 5.11 update here: https://files.fm/u/k2kgtccp The LST files were fixed and all files should be extracted to the root of the USB stick (it's in a folder but the edited LST files have no folder path). Try formatting the USB stick as exFat or Fat32 and un-zip the files onto the USB directly. If the update is recognised, you will need to leave the engine running for the full update which takes about 25 minutes. You can do the update while driving and it will announce when the update has been completed. 2 Quote Link to comment Share on other sites More sharing options...
innovatetom Posted April 7, 2019 Author Share Posted April 7, 2019 Thank you @Zico I shall give this a try later on / tomorrow and post back how I get on 🙂 Quote Link to comment Share on other sites More sharing options...
innovatetom Posted April 7, 2019 Author Share Posted April 7, 2019 OK so it updated to 5.11 with the files you gave me, thanks! The applications section still says 'Update needed, request update' so I guess my car doesn't have app link support after all? Quote Link to comment Share on other sites More sharing options...
Zico Posted April 7, 2019 Share Posted April 7, 2019 The App link app's are few and far between (Spotify was one of them but think it's been blocked in the newer Spotify app versions) and I don't think I've ever used any. The Sync may need resetting or re-pairing to your phone as I've had a glitch in the past after updating. Quote Link to comment Share on other sites More sharing options...
sync 1.1 update Posted April 10, 2019 Share Posted April 10, 2019 Will these files work on a 2014 c max with sync 1.1? I can't get the download for mine to work. Quote Link to comment Share on other sites More sharing options...
Zico Posted April 10, 2019 Share Posted April 10, 2019 I used the VIN of a 2016 Fiesta Titanium to get the download from Ford. I can't say for sure if they will work for you or not. I believe that the 1.1 module is the same but I can't say confirm that as I've no experience of the module's used across the range. If you download the update I would hazard a guess that it would be rejected if it's not the compatible version during the update process. Quote Link to comment Share on other sites More sharing options...
Norbi1991 Posted November 27, 2019 Share Posted November 27, 2019 Hello I've issue with Applink update. Current version is FR3T-14D544-AG and using my VIN i found update to FR3T-14D544-AN. When I try to upgrade it from USB I have message "No CD" and nothing happen. Pendrive is recognized because .mp3 work from it. Do you have any ideas? Quote Link to comment Share on other sites More sharing options...
Zico Posted November 27, 2019 Share Posted November 27, 2019 1 hour ago, Norbi1991 said: Hello I've issue with Applink update. Current version is FR3T-14D544-AG and using my VIN i found update to FR3T-14D544-AN. When I try to upgrade it from USB I have message "No CD" and nothing happen. Pendrive is recognized because .mp3 work from it. Do you have any ideas? There are a few things you can try. 1) Check the filenames all match in the autoinstall.lst and install.lst files. You can open the files in Notepad / Wordpad on a PC. The lines below are from a previous Sync update, check each item matches each open line (ignore the .cab on the end). From the install.lst ; Assembly Directive Install for Gen 1.1 16B - E1BT [Windows Mobile for Automotive 5.8] Item1 = 8L2T-14D546-AF Open1 = 8L2T-14D546-AF.cab Item2 = E1BT-14D546-EB Open2 = E1BT-14D546-EB.cab Item3 = E1BT-14D546-JC Open3 = E1BT-14D546-JC.cab Item4 = E1BT-14D546-DB Open4 = E1BT-14D546-DB.cab Item5 = E1BT-14D546-AA Open5 = E1BT-14D546-AA.cab From the autoinstall.lst [Windows Mobile for Automotive 5.8] Item1 = 8L2T-14D546-AF Open1 = 8L2T-14D546-AF.CAB Item2 = E1BT-14D546-KC Open2 = E1BT-14D546-KC.CAB 2) Try formatting the USB stick as FAT32 and try again. If you have a USB 2.0 stick try using this as has worked for me where a USB 3.0 drive didn't work. Quote Link to comment Share on other sites More sharing options...
Norbi1991 Posted November 27, 2019 Share Posted November 27, 2019 I have exacly the same filenames (changed vith compare function). The only difference is that files are placed in SyncMyRide folder so every entry looks like this Item1 = 8L2T-14D546-AF Open1 = SyncMyRide\8L2T-14D546-AF.cab I use USB 2.0 stick. It is strange for me that every time I try to start update is tells me "No CD" Quote Link to comment Share on other sites More sharing options...
Zico Posted November 27, 2019 Share Posted November 27, 2019 The SyncMyRide folder is the default path but I removed this when I edited and corrected the lines and extracted all files to the route folder of the USB drive. I don't know why it would say "No CD". Do you have a CD in the disc drive? Only other thing I can recall is that I inserted the USB drive into the car before turning the ignition on, then it seemed to recognise that there was an update available. Quote Link to comment Share on other sites More sharing options...
welshysss Posted January 7, 2020 Share Posted January 7, 2020 @Zico I'm trying to do the same update. Any chance of re-sharing your files? Can't access them from the link you provided earlier? Quote Link to comment Share on other sites More sharing options...
Zico Posted January 7, 2020 Share Posted January 7, 2020 @welshysss re-uploading now. Will post the link when done. **Edit** Done: https://files.fm/u/cg2kbca9 1 Quote Link to comment Share on other sites More sharing options...
pin8all Posted April 30, 2020 Share Posted April 30, 2020 @Zico Could you possibly upload these files again Quote Link to comment Share on other sites More sharing options...
Zico Posted May 1, 2020 Share Posted May 1, 2020 @pin8all this link is still active: https://files.fm/f/kv2e9bwx See this post for the re-upload. Good for 2 months from the date of upload: 1 Quote Link to comment Share on other sites More sharing options...
pin8all Posted May 1, 2020 Share Posted May 1, 2020 @Zico worked first time with your files, spent hours with mine from the Ford site. Thank you so much. 1 Quote Link to comment Share on other sites More sharing options...
Zico Posted May 2, 2020 Share Posted May 2, 2020 No worries @pin8all. I'm going to guess that if you downloaded the files from Ford directly that they still have the typo in the *.LST files where the name of one or more of the CAB files doesn't match up. It was something found by another user on the forum ages ago and for some reason on pretty much all of the Sync 1.1 files released from Ford has had a typo in them. Quote Link to comment Share on other sites More sharing options...
Sasqwatch Posted June 27, 2020 Share Posted June 27, 2020 Sorry to be a pain, but can you re-upload the files again. I just went to download them, and they are not there. This is for SYNC on a 65 plate Fiesta. Thanks Quote Link to comment Share on other sites More sharing options...
Frank Machin Posted June 27, 2020 Share Posted June 27, 2020 Hi all like the Op I recently tried updating my 65 plate Fiesta Titanium ecoboost. Went to Ford website with my VIN, downloaded the update, formatted numerous USB sticks to FAT32. Extracted the files, copied them over to the differnt sticks and i keep getting files not found on every usb stick.. Anyone able to upload the working files please? cheers Quote Link to comment Share on other sites More sharing options...
Zico Posted June 28, 2020 Share Posted June 28, 2020 Re-uploading the file as we speak. Will edit post when done. The likelihood is that the Ford's download has the typo's on the filenames which is partly why it doesn't work. The uploaded file has simply had the filenames corrected. **Edit** Link is good for 2 months: https://files.fm/u/f9w36mpq 1 Quote Link to comment Share on other sites More sharing options...
Frank Machin Posted June 28, 2020 Share Posted June 28, 2020 Thankyou very much Zico. 1 Quote Link to comment Share on other sites More sharing options...
Sasqwatch Posted June 28, 2020 Share Posted June 28, 2020 Thanks. Quote Link to comment Share on other sites More sharing options...
Frank Machin Posted June 28, 2020 Share Posted June 28, 2020 Just to be clear. Do i copy the files onto the usb either into one overall folder named E1BT-14D544-AN-PKS or as they are? SyncMyRide,autoinstall. lst and install.lst? Quote Link to comment Share on other sites More sharing options...
Frank Machin Posted June 28, 2020 Share Posted June 28, 2020 7 minutes ago, Sasqwatch said: Thanks. Let me know how you get on Sasqwatch please. Quote Link to comment Share on other sites More sharing options...
