mcchic Posted April 8, 2019 Share Posted April 8, 2019 Hi all Bought a non starter a ford focus ecoboost 1.0 litre 2013 . Lots of fuel and.battery but no spark at all. No faults showing on my diagnostickets toold after resetting . Had ecu and body control unit checked. Any ideas and also checked the immoblizer system everything fine Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 8, 2019 Share Posted April 8, 2019 Are you using Ford diagnostics or something generic? Would be worth trying Forscan if only using generic. Would check that cam and crank are synchronized as a start as they won't fire if not. 1 Quote Link to comment Share on other sites More sharing options...
mcchic Posted April 10, 2019 Author Share Posted April 10, 2019 It's a snap on diagnosis tool . Will it do any damage if they are slightly out..engine got full compression Quote Link to comment Share on other sites More sharing options...
Mark D S Posted October 19, 2020 Share Posted October 19, 2020 There is an earth point for the coil packs under the inlet manifold on the gearbox end, Quote Link to comment Share on other sites More sharing options...
