WoldsWarrior Posted April 30, 2019 Share Posted April 30, 2019 Morning! Ive recently bought a 2009 Zetec S 1600 petrol, with 52k on the clock, and im just working my way through a few faults. Recently done the Bonnet Catch and Boot Latch, sorting two issues out straight away. I have noticed when driving along at a speed, say 60, that the slightest touch of the throttle causes the car to feel like small judder but isnt actually a judder. Would this maybe be a coil pack issue? Its hard to describe, more like a small jerking feel. Its getting the Rear Axle Bushes done on Thursday and a full service, inc Cambelt Kit and Water Pump, so im hoping it just needs a refresh. Thanks Quote Link to comment Share on other sites More sharing options...
CordonFreeman Posted April 30, 2019 Share Posted April 30, 2019 My fiesta 1.4 p doing same, i had my gearbox, clutch and mounts replaced (for another problem) and i still have same problem, i think can be coil pack, o2 sensor or vacum leak Quote Link to comment Share on other sites More sharing options...
WoldsWarrior Posted May 14, 2019 Author Share Posted May 14, 2019 Replaced Coil pack and leads, and Plugs, and still there. Im wondering if its the engine mounts now in all honesty. Common thing? Quote Link to comment Share on other sites More sharing options...
CordonFreeman Posted May 15, 2019 Share Posted May 15, 2019 I dont think its mounts...Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
wild_one Posted May 16, 2019 Share Posted May 16, 2019 Have you scanned for any codes? Give the MAF a spray? Quote Link to comment Share on other sites More sharing options...
WoldsWarrior Posted May 16, 2019 Author Share Posted May 16, 2019 5 hours ago, wild_one said: Have you scanned for any codes? Give the MAF a spray? To be fair, no, i haven't, ill get my mate who's a self employed ex Ford tech to have a scan for me. Is the MAF on the air intake off the airbox on these? Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted May 16, 2019 Share Posted May 16, 2019 You can scan it yourself: Ford Fiesta MK7 hidden menu procedure Press and hold trip reset button on the instrument cluster. Turn ignition on with key or by pressing START button without clutch. After few seconds “test” message will appear on the display. Release the button. Browse the Ford Fiesta MK7 hidden menu with trip reset button. Quote Link to comment Share on other sites More sharing options...
wild_one Posted May 16, 2019 Share Posted May 16, 2019 6 hours ago, WoldsWarrior said: To be fair, no, i haven't, ill get my mate who's a self employed ex Ford tech to have a scan for me. Is the MAF on the air intake off the airbox on these? Yes, you'll see it near the airbox with a multi connector. Two little torx screws to remove it. Tread lightly they are fragile, and do not be tempted to touch the wires. Only use MAF spray or alcohol. Nothing to lose by cleaning it. Quote Link to comment Share on other sites More sharing options...
WoldsWarrior Posted May 17, 2019 Author Share Posted May 17, 2019 11 hours ago, wild_one said: Yes, you'll see it near the airbox with a multi connector. Two little torx screws to remove it. Tread lightly they are fragile, and do not be tempted to touch the wires. Only use MAF spray or alcohol. Nothing to lose by cleaning it. Yeah i thought that was it. Used to sell loads when i worked for a Vauxhall Dealer back in the early 2000's! Quote Link to comment Share on other sites More sharing options...
