Mark 1 Posted May 8, 2019 Share Posted May 8, 2019 Clutch Fault Diagnosis Hi guys, My 2004 Focus 1.8 petrol has lost all resistance in the clutch pedal rendering it totally ineffective. I fitted a new three part Borg and Beck clutch kit four months ago and the clutch has been fine until now , therefore , although not impossible , I am reluctant to suspect the slave cylinder ( due to its relatively recent renewal) , leaving the master cylinder as the only other possible culprit ! My question is :- Is there a way of finding out for sure whether the master or slave is at fault ? Thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 8, 2019 Share Posted May 8, 2019 Check to see if drivers foot well is wet with brake fluid and take a look up at the top of the clutch pedal master cylinder sits at the back of it and it made of plastic and is known to break 🙂 Quote Link to comment Share on other sites More sharing options...
