Sign in to follow this
Max-
Help Required-1996 1598cc 16v..No Ignition Light
Hi, can anyone help?
1996 Ford Escort 5Dr Hatch, 1598cc 16valve manual, Petrol....24000 original miles!
No Ignition Light and have replaced alternator checked wiring as says in Haynes manaul, Alternator not charging above 12.45 volts. battery is ok, Voltage 12.45 Volts when engine idling or off. Voltage appears to drop when increase revs or apply electric load ie; Lights etc.
Wondered if anyone has a solution and has come accross this before? BTW Checked continuity up to dash and checked Bulb...Bulb ok and have continuity from alternator.?
Thanx
Max-
  Only 75 emoji are allowed.
