Morrisg Posted May 16, 2019 Share Posted May 16, 2019 Hello I have a problem with DAB Radio not working on Mk5 Mondeo on Sync2. All other wavebands and sync2 functions work fine . Please see attached photo I Read fuse removal/replacing might cure problem but will I then need 4 digit security code. Bought car 6 weeks ago and have no idea what pin is if needed. Any help much appreciated. Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted May 16, 2019 Share Posted May 16, 2019 2 hours ago, Morrisg said: Hello I have a problem with DAB Radio not working on Mk5 Mondeo on Sync2. All other wavebands and sync2 functions work fine . Please see attached photo I Read fuse removal/replacing might cure problem but will I then need 4 digit security code. Bought car 6 weeks ago and have no idea what pin is if needed. Any help much appreciated. I'm pretty confident that you don't need a 4 digit code because the unit is coded to the car. Have you read somewhere that you need a code for Sync 2 or just assumed because older type head units usually needed one? Quote Link to comment Share on other sites More sharing options...
gg1234635 Posted May 16, 2019 Share Posted May 16, 2019 Do a hard reset on it and that should sort the problem. It looks like its a error in the code so removing the fuse might not resolve it. Have a look on Youtube and it will show you how to do a hard reset Quote Link to comment Share on other sites More sharing options...
Morrisg Posted May 19, 2019 Author Share Posted May 19, 2019 I'm pretty confident that you don't need a 4 digit code because the unit is coded to the car. Have you read somewhere that you need a code for Sync 2 or just assumed because older type head units usually needed one?Yes just assumed thank you so much Sent from my ONEPLUS A6013 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Morrisg Posted May 19, 2019 Author Share Posted May 19, 2019 Do a hard reset on it and that should sort the problem. It looks like its a error in the code so removing the fuse might not resolve it. Have a look on Youtube and it will show you how to do a hard resetThanks very much appreciate your helpSent from my ONEPLUS A6013 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Morrisg Posted May 19, 2019 Author Share Posted May 19, 2019 I have done SYNC2 master reset but still get no joy with DAB exactly the same Noticed had to re-pair phone and Nav favs need to be setup again but all radio presets were there in entertainment.As I say DAB non responsive to anything I do stays on LED 1 out of 3 when touched and never moves touching presets or trying scan does nothingAny other ideas would be much appreciated.Sent from my ONEPLUS A6013 using Tapatalk Quote Link to comment Share on other sites More sharing options...
BigPete1983 Posted June 7, 2019 Share Posted June 7, 2019 On 5/19/2019 at 2:59 PM, Morrisg said: I have done SYNC2 master reset but still get no joy with DAB exactly the same Noticed had to re-pair phone and Nav favs need to be setup again but all radio presets were there in entertainment. As I say DAB non responsive to anything I do stays on LED 1 out of 3 when touched and never moves touching presets or trying scan does nothing Any other ideas would be much appreciated. Sent from my ONEPLUS A6013 using Tapatalk Do you have dash cam installed in your car? Some dash cams can kill DAB signal, also some dodgy devices such as car phone chargers etc. Try to remove all electronic devices from your car. It may help. Quote Link to comment Share on other sites More sharing options...
gg1234635 Posted June 7, 2019 Share Posted June 7, 2019 I am sure someone on the FOrd Mondeo MK5 uk group might be able to assist you. link is below https://www.facebook.com/groups/693277794183606/ Other thing i would look if you can is using a program called forscan and see if you can see anything on that with the dab in the presets and settings. 1 Quote Link to comment Share on other sites More sharing options...
mi0uft Posted June 14, 2019 Share Posted June 14, 2019 I had the same problem with my mk4. removed and replaces fuse and yes had to re-enter code. the DAB worked fine then. Quote Link to comment Share on other sites More sharing options...
