D13 HPD - ST180
D13 HPD 95
聽Share
@D13 HPD 95 looks like you added a ST washer fluid cap 馃槉. Why did you change the engine cover also from the painted one?聽
Yh st sticker and a shaved grill for more air flow, and I wanted a stock oem+ look not a showy painted one 馃檪
Front upper strut installed!聽
Running out of mods in the shed to install now聽
Didn't you have a painted engine cover?聽
He said above he wanted a more stock OEM+ look rather than a showy one
Sorry I forgot I asked that previously 馃槄
Yesss I do 馃檪聽less showy more oem+ is the look I want聽
added to that the second catch can finally fitted and plumbed in聽
Little clean and also removed the vinyl from the doors for more body colour聽
An update on what鈥檚 going on this next few weeks聽
So done a mini service today, new ITG filter head old one was past a wash an re-oil so new head it is
fitted a new pollen filter ( I don鈥檛 know how old the last one was but it certainly wasn鈥檛 changed in Jan when the last service was carried out 馃檮 apparently )聽
so on the above a mate is helping me fit the R sport baffled sump, with sump plug, new filter and obs an oil change 馃檪聽to some nice Fuchs Titan pro S 5w30 sweet goodness聽
new plugs to go in as well聽
airtec hotside pipe聽
airtec stage 3 cooler ( so I can fit the airtec oil cooler I cannot with the pro cooler currently fitted )
got myself a cheap set of B8 dampers brand new - so going to get new top mounts and bearing front and rear, and new rear upper spring isolators ( currently have powerflex black series on but they make the rear of the car sit 10mm ish higher than it should and Ford re-released some proper rubber ones not foam so they won鈥檛 fall apart )聽
new front arb drop links adjustable so I can get the front set up currently again聽
If got the cam fuel tappet to change at some point聽
transmission oil to replace聽
fitted the shifter base bushes today makes the changes a lot more precise - I have the transmission bracket ones to do聽
new Cobb rear torque mount with strength plate to install聽
also looking to swop my cobra exhaust for a milltek non res race one聽
annnnnnd getting some 16inch OZ superturismo alloys with ad08r tyres just need a refurb聽
then she鈥檚 ready for the oil cooler fitted after next month and the x47r turbo with maxd mapping left to do!聽
Plans hey聽
also house move will be completed within next 5 weeks woop聽聽
happy happy days聽
New set of plates to get on聽
airtec cooler ready for install
and last of the red hoses in the engine bay all gone ultra stealthy look now聽
@D13 HPD 95 would you say the plate looks great with or without the border? Just in the process of getting a plate so deciding 馃槄
I went for one as I鈥檝e never had the border before so thought why not haha聽
New Cobb mount fitted along with a retaining brace to help reduce stress across one bolt and split the stress to multiple bolts decreasing chance of snapping the main mount bolt and also allowing the mount to stay straight and not twist聽
New airtec cooler and airtec hot side fitted today
Definitely a stealthy discreet look going on
I'd love to have it exposed myself but does look like a sleeper.聽
Can I ask how you've attached your plates to the bumper? Just wondering how I should attach my new plates to my car. I bought a discreet plate holder but just want a clean look.聽
Cheers it鈥檚 a lot less in your face and not noticeable聽
Double sided 3M tape mate holds it perfectly聽
Big day today suspension upgrade
new B8 dampers聽
new ebiach redline springs
new front top strut mounts and bearings
new adjustable front drop links聽
new rear spring isolator pads聽
and a summit 4 point lower chassis brace聽
also pics of the airtec hotside聽
car feels like its on rails now, tyres are letting it down round corners so need to figure out if I鈥檓 getting new alloys or new tyres聽
also the rear needs an arb to keep the back end flat as it shifts round to much
New set of PS4鈥檚 for the rears due to a puncture and getting close to limit should keep the rear in check more now聽
And bless it hit 66k聽
Cheeky buy for myself 馃檪聽a set of DNA racing light weight front wishbone arms with uniball joints these are meant to last forever these joints due to their unique oil filled joints they don鈥檛 rot don鈥檛 break and don鈥檛 perish over time so hopefully these will outlast the car! Also uniball joints are known for using in racing teams as they give more steering response and feedback than just polybushs also even though polybushs are cheaper and last longer than stock rubber they still diminish聽and perish over time but are 1/3 of the cost!聽
Mill use polybushs in certain areas where I don鈥檛 justify uniball joints, like the rear beam connection Bush, I鈥檒l fit polybushs in them as they are 拢70 instead of 拢400 for a set of uniballs and tbh I鈥檓 not sure how much more the rear the needs controlling stiffening up after a rear roll bar which is next on the list I think!聽
Perks of working away up north for a week, get to check out the local Facebook market place items for sale and notice a seriously cheap milltek non res race cat back exhaust only an hour from your hotel, well it鈥檚 rude not to pick it up ain鈥檛 it聽
and a cheeky celebration pint聽
Another cheeky couple of buys while I was away! Picked up a second hand airtec catch can but no hoses聽
also some new DMB st badges, got a new vision for the car coming soon slick not to in your face but some would call it Fubaru
Probably won't be much for the hoses since you got the main thing 馃憤
Big day today聽
New gel vent rings from DMB聽
new steering wheel riders thicker and nice alcantara top and bottom with blue stitching and a blue ring (not fitted yet)
New ST badges on and removed the Mountune lip finally聽
Picked up some Team Dynamics Proc Race 3 17x7 et 35 so will sit slightly more in the arch than the current wheels these are being refurbed in a nice Subaru gold
New PS4 tyres fitted on the front current alloys so matching PS4s on the car now feels lovely and grippy聽
picked up a delta spoiler with carbon blade needs painting in blue though聽
fitted an R-Sport baffle in the sump with a magnetic sump plug聽
here鈥檚聽the state of the old oil filter which was apparently fitted in January of this year by the state of the oil its been at least 20k miles since it was last changed聽
new powerflex聽engine mount insert fitted on the drivers side still have passenger gearbox side to do聽
milltek exhiast fitted聽
DNA racing wishbone arms fitted聽
old red coolant hoses removed and stock hoses fitted again so no more leaks, with fresh coolant as well聽
She鈥檚 sitting pretty and the drive home was insane! I can not wait to get it aligned correctly as it鈥檚 slightly off and get this thing on track now!聽
I think those wheels will look nice in that gold. Your lucky that the oil filter didn't break open otherwise oil would of leaked out and damaged the engine 馃槵. Need to get my tracking done before MOT. Dad loosened the front joints so the tracking place try not to charge more by saying they struggled to loosen it. In result however the tracking is more off that the steering wheel is facing 30 degrees left when the wheel is facing forward.聽
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
聽Share
