Kaski
Mondeo in limp mode, fault code P2263
And sorry for a rather long post.
Some days ago the first problem occurred with my 2009 Mondeo 2.0 tdci (125 000 miles).
During a 250 mile trip the car suddenly went into limp mode, a little more than halfway into the trip.
Preconditions worth to mention are that a (empty) horse trailer was behind the car, ambient temperature 26°C, a bottle of Forte DPF cleaner was added to the topped-up fuel tank before start, and two days earlier I had changed the oil.
When the car went into limp mode the ABS light came on and the following fault codes were read with Torque Pro:
- P1719
- P2263
The fault codes were reset and I restarted the car, which then was back to normal.
Then I also realized that Torque (and the used OBD dongle) doesn't support MS CAN..
After 12 miles it happened again.
Then I booted my laptop and read the codes with Forscan. Forscan log attached, but in short:
===TCM DTC P1719:00-27===
Code: P1719 - Engine Torque Signal
Status:
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
===TCM DTC U0401:00-27===
Code: U0401 - Invalid Data Received from  ECM/PCM A
Status:
===PCM DTC P2263:72-27===
Code: P2263 - Turbocharger/Supercharger A Boost System Performance
Additional Fault Symptom:
 - Actuator Stuck Open
Status:
===OBDII DTC P2263-P===
Status:
 - Pending - malfunction is expected to be confirmed
===ABS DTC U3001:00-08===
Code: U3001 - Control Module Improper Shutdown Performance
Status:
 - Previously Set DTC - Not Present at Time of Request
===ABS DTC U0401:68-8A===
 - Event Information
Status:
 - Malfunction Indicator Lamp is On for this DTC
Module: Antilock braking system
===RFA DTC P1571:62-08===
Code: P1571 - Brake Switch
 - Signal Compare Failure
Status:
===RFA DTC U0402:68-08===
Code: U0402 - Invalid Data Received from TCM
 - Event Information
Status:
Cleared the fault codes, restarted the car, and tried to take it easy in order to get all the way home.
After Another 80 miles it happen once again right after a short stop. But now it wasn't far from home.
since this (4 days later) it hasn't happened again during ~180 miles of shorter trips.
The fault code U0401 was also preset the day after the limp mode, but not active and this time the malfunction indication light was not activated..
===ABS DTC U0401:68-48===
 - Event Information
Status:
 - Test not complete
Was it actually the turbo vanes sticking, maybe caused by the DPF cleaner?
CAN error?
Also noticed that a small amount of oil had dripped on a connector right under the oil filling pipe during the oil change.
Any help, advice or similar experience would be grateful.
190519_1.txt
On 5/23/2019 at 9:59 PM, Kaski said:
- P1719
- P2263
Status:
Status:
Status:
Status:
Status:
 - Event Information
Status:
Status:
 - Event Information
Status:
- P1719
- P2263
Status:
Status:
Status:
Status:
Status:
 - Event Information
Status:
Status:
 - Event Information
Status:
 - Event Information
Status:
 - Test not complete
CAN error?
190519_1.txtUnavailable
Hi! Did you sort this fault codes out? I have the same codes in the same say with my ford s-max 2.0 tdci.
 - Event Information
Status:
 - Test not complete
CAN error?
Hi, I'm afraid I'll disappoint you a bit..
It has never come again since that day, so I suppose it must have had to do with the DPF cleaner, or something else external that affected the car only that day.
Has your issue been for a longer time, how frequent is it?
My happens all the time.
New egr valve that is calibrated but still opens fully at idle? Don't now why and fault codes says turbo ower boost and turbo stuck open. Can the egr activate those codes?
  Only 75 emoji are allowed.
