Grimey1990 Posted June 10, 2019 Share Posted June 10, 2019 Hi all, My 2008 ford focus has a really high biting point, which I'm just so uncomfortable driving. I heard you can fasten some bolts near the pedal, but i wanted to find out if this will work before attempting and making things worse. I learned in a 2018 fiesta, which i feel very comfortable in, the biting point is just over half way up. My focus however, is almost all the way up. Any help would be much appreciated. 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted June 20, 2019 Share Posted June 20, 2019 On 6/10/2019 at 8:40 PM, Grimey1990 said: Hi all, My 2008 ford focus has a really high biting point, which I'm just so uncomfortable driving. I heard you can fasten some bolts near the pedal, but i wanted to find out if this will work before attempting and making things worse. I learned in a 2018 fiesta, which i feel very comfortable in, the biting point is just over half way up. My focus however, is almost all the way up. Any help would be much appreciated. The clutches on most/all modern cars are self adjusting, it's not possible to make adjustments to alter the biting point. Quote Link to comment Share on other sites More sharing options...
isetta Posted June 20, 2019 Share Posted June 20, 2019 I agree with the above response. Whilst it would be difficult, the only way I can think that this could be done is a) move the clutch master cylinder further forward and put a bigger rubber stop at the top of the travel. as I say, difficult and would require some trial and error particularly to ensure no clutch drag or b) shorten the push rod that goes from pedal to clutch master cylinder. difficult due to the shaped end on the rod, or difficult to join if you cut a piece out of the middle , would require some trial and error particularly to ensure no clutch drag or c) deliberately introduce some air into the fluid line between clutch master and slave cylinder. would require some trial and error particularly to ensure no clutch drag So not quite impossible but totally impractical and difficult Quote Link to comment Share on other sites More sharing options...
