Drkanglnomad Posted June 14, 2019 Share Posted June 14, 2019 So the rear drivers side door trim (rub strip,slam strip, etc) has a piece snapped off. Looking to get a replacement just cus looks tacky at the mo. Found a couple of options. Either silly prices £70+ or absolute bargains £12. My question is, and may sound stupid, but a trim from the same door on a 5 door mk6.5 facelift will fit the mk6 pre-facelift. Am I correct? Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted June 14, 2019 Share Posted June 14, 2019 The mk6.5 door strips will fit onto a pre facelift, although they are much wider so will look silly unless you replace the front ones at the same time, when I had my old mk6 I replaced my ones with the mk6.5 colour coded ones, which in my opinion looked much better than the standard narrow textured plastic ones. 1 Quote Link to comment Share on other sites More sharing options...
Drkanglnomad Posted November 23, 2019 Author Share Posted November 23, 2019 Cheers for that. Will look into getting color match for mine then Quote Link to comment Share on other sites More sharing options...
zain611 Posted November 24, 2019 Share Posted November 24, 2019 Can I ask how you'll remove it? Just wondering for later on if I might decide to remove it for spraying Quote Link to comment Share on other sites More sharing options...
Fiesta1.25 Posted November 24, 2019 Share Posted November 24, 2019 Easily removed using a heat gun or hair dryer to warm up the double sided sticky tape and a piece of fishing wire or dental floss very easy to do, I’d highly recommend you colour coding them as they look so much better [emoji106] Quote Link to comment Share on other sites More sharing options...
Paulkp Posted November 24, 2019 Share Posted November 24, 2019 I colour coded door and hatch handles too, get some from a scrappy to save all the rubbing down Quote Link to comment Share on other sites More sharing options...
