Sign in to follow this
LondonFiesta
Streaming music on Bluetooth
I’ve done a search, can’t find what I need
Also can’t find my manuals...
How do you stream music over bluetooth? I have a 2014 car (64) with the standard Zetec stereo, has a bluetooth phone set up.
I see I can play via USB, haven’t tried that yet but can’t see an option for streaming.
Thanks!
You dont have the steaming option only via usb.to get streaming you need an updated  bluetooth module, sorry cant tell you what number the module will need to be, hopefully someone will come along with the info
A 2014 zetec should have the SYNC system as standard (basically fancy bluetooth that's also capable of music streaming). Should just be a case of pressing the aux button till you get this screen. Shouldn't be any need to change modules though.
IMG_0004.thumb.jpg.bf27c8a7caca7120c9d6bf8a56bbdc46.jpg.acee46520c02d727322b4927f35c532a.jpg
Great thanks. Will pop out and take a look in a bit
This.  Also, make sure your phone is paired with sync ok as well (sometimes it can be temperamental but its nothing a sync reset and re-pairing wont fix).  My previous Fiesta's worked fine with both Apple and Android (even the almost poverty spec "edge"), as does my current Fiesta
...just a heads up when SYNC upgrading, maybe consider the following: do all the things on the upgrading list, Except turning your engine on!
almost drove mine into a ditch and put a match to it, it did not work when I followed the list,
A nice Aussie guy told me not to turn on my engine, and whatta you know 🙂
c",) Jan
I have a 2015 ecoboost, about 2 weeks ago my bluetooth stopped working and will not pair to android or apple, I have tried to update sync and sync will not recognise my usb
Try taking the fuse out or disconnecting the battery
c",) Jan
c",) Jan
Interesting! How long does it take? Concerned the battery will be knackered!
About 15 minutes, turn off A/C and lights then You should be good to go. It's a fairly big battery on cars with auto Start/stop, and the small amount of power needed to run the Radio/update will not have that much of an impact
🙂 Jan
...Oh, btw. My local Ford dealer ship confirms that the updating list doesn't seem to work on models made before april 2017, so it would seem that the list is for the new model only.
🙂 Jan
Thank you very much I will give that ago tomorrow 🤙
A sync update is unlikely to fix this. You need to first make sure your model can be updated. Go to your radio settings and find the info section. Look for the letters D1BT or AM5T (or something very similar). The latter is Sync 1.0 and cant be updated.
I think mine is SYNC 1 being a 2014 car. I put in my VIN on the ford site and it says it needs an update?
Downloaded the update and extracted to my USB...
Attempt 1: make sure the files are on root directory. Checked, two files and one folder so dropped files from folder to root directory
Attempt 2: still doesn’t recognise the files on the root directory
Attempt 3: deleted and redid the download, stored all files on root directory...
So still failing, got the same ‘make sure files stored to root’ message.
Anyone got any ideas on this? I used up my only free half hour today so will have to try again next week.
Attempt 4: found the issue about extracting the files from zip and followed the instructions on renaming the root folder in the auto install file and install file....still not working. I reformatted the USB to 16b 32FAT before too. 32GB new stick. Works fine otherwise.
Anyone know what I’m doing wrong?
No, no file name like that. I don’t have it with me but was a bunch of files with the same name but ending with two capitals, apart from one that had .sec as an extension and the two install files
https://www.google.com/amp/s/amp.reddit.com/r/Ford/comments/4djkyq/cant_update_my_sync_software/
There should be instructions on how to update sync1. It was a long ago but when I updated mine (car is 2014/2015 mk7.5 Fiesta) I had to edit some text file to make things work. I quickly glanced through that topic and it seemed there are the same instructions I followed.
Great thanks all. I will try the exFAT approach and check the files. One of the other threads I found said to not have any files on the drive, not even the syncmyride/ one
Will report back next week
  Only 75 emoji are allowed.
