Kapowster
Ford KA 15 plate dashboard warning light
First time poster I’ve got an amber warning light appearing on my dashboard couldn’t find it in the user manual but according to online it’s the control lighting warning light. I’ve checked all the lights on the car and they all seem only has anyone else experienced this?
Ok, bulb failure. Have you had the need to replace any bulbs recently. Have you checked brake lights? And checked side repeaters
Yes I’ve checked all the lights and the are ok - also I should have put this in the original post this morning after driving for about 15 minutes the warning light went off. When I then started the car again it was back on 🤷🏻‍♀️
To put that warning light on its detecting a fault with one of your bulbs even though they still work, one of the bulb circuits is giving a higher or lower current reading.  Possibly an issue with one of the connectors. I would try unplugging connectors and checking for any signs of corrosion. Try one at a time and see if any particular one  puts  the light out.
Thanks so much for your replies they’ve been a great help
  Only 75 emoji are allowed.
