MJJ94 Posted June 19, 2019 Share Posted June 19, 2019 Found that the headlight mount was broken so took it to TrustFord. I’ve attached a picture of the problem. They want £200 to replace my headlight. It looks like the other side is also slightly weakened (as though ford have sabotaged it ready to break) i likw to consider myself a steady driver so I’m quite annoyed that ford are accusing me of damaging it with impact. Any ideas how this can be fixed without a new headlight. Is there some glue I could botch it with? if I were to botch it would that have any consequences. Just so you know the car is almost a year old Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted June 19, 2019 Share Posted June 19, 2019 Whenever someone has come to me with a broken headlight bracket I just use an old soldering iron to melt the plastic back together. I usually have a little piece knocking around to use as filling material if required. As long as you can line the two pieces back up relatively well (yours should be dead easy) you won't be able to tell when the bonnets shut. I've had one where the bracket broke off right at the headlight, so had to sort of guess where it went back together, Quote Link to comment Share on other sites More sharing options...
MJJ94 Posted June 19, 2019 Author Share Posted June 19, 2019 Thanks for the reply I’ve screwed 2 metal brackets on it to hold it in place. I’ll keep my eye on it. I don’t see the point in forking out for a new headlight if it’s unoticable Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted June 19, 2019 Share Posted June 19, 2019 I don't see how they can imply that you've broken this through impact if there's no other damage (eg to the light itself or surrounding bodywork). Other members have reported this bracket breaking and had theirs sorted under warranty. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 19, 2019 Share Posted June 19, 2019 Is the bonnet hitting the headlights when it's closed? I've never seen headlight brackets just randomly snap on any other car but it seems to be happening regularly on the Mk8s!! As above though....if you're supposed to have damaged them, ask them to point out the rest of the impact damage... 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted June 19, 2019 Share Posted June 19, 2019 Take it back to your dealer tell them there talking *****. That is warranty due to the height of the bonnet breaking the mounting point on headlamp. Tell them to check there technical service bulletins. A repair kit is available and replacement headlamps are not required. 2 Quote Link to comment Share on other sites More sharing options...
Mavroz Posted June 19, 2019 Share Posted June 19, 2019 Ours were sorted out under warranty. Both were broken or damaged, wobbly headlights. Looks like a fix and not a replacement but works fine. 2 Quote Link to comment Share on other sites More sharing options...
p.harv Posted June 19, 2019 Share Posted June 19, 2019 I had my drivers side headlight replaced under warranty after noticing a wobbly headlight washing my car. The car at the time was only 3 weeks old - took them around a month to get a new headlight at the time though!! Cheers - Paul. Quote Link to comment Share on other sites More sharing options...
Paulkp Posted June 19, 2019 Share Posted June 19, 2019 What might break a plastic tab like that might be over tightening the screw - On a Puma radiator grille I just araldited another strip of plastic over the top. Quote Link to comment Share on other sites More sharing options...
Joseph1984 Posted January 8, 2022 Share Posted January 8, 2022 My 2019 st-line x and my mrs 2018 1.1 vtech have both got 1 Headlight clip broken Quote Link to comment Share on other sites More sharing options...
BlueMike2021 Posted January 8, 2022 Share Posted January 8, 2022 It's a common fault- they are slightly stressed and can easily crack even when just sat in situ. One of mine was held together (just) with Araldite when I got the car- later when I shifted the headlight unit it just fell apart, so I knocked up a (very) quick bit of metal that does the job nicely, though I'll make something that looks better when I have a minute- Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 8, 2022 Share Posted January 8, 2022 32 minutes ago, Joseph1984 said: My 2019 st-line x and my mrs 2018 1.1 vtech have both got 1 Headlight clip broken 1 1 Quote Link to comment Share on other sites More sharing options...
Henryge Posted January 9, 2022 Share Posted January 9, 2022 Hi There, I made a metal plate to cover the actual bracket from screw area to curve of headlight. drilled clearance hole for screw into metal holding point, Then drilled 2 smaller clearance holes (In metal plate) over plastic tab area to screw into then pilot holes in plastic tab. Before ***** together used aridite to join together then screw in place. Much better solid join. Also try eBay search for your make and model year for repair bracket on headlights. Hope this all helps Quote Link to comment Share on other sites More sharing options...
unofix Posted January 9, 2022 Share Posted January 9, 2022 3 minutes ago, Henryge said: Before ***** together used aridite to join There is no 5crewing allowed on this forum. Humping is OK 🤣 2 Quote Link to comment Share on other sites More sharing options...
Doylie Posted January 14, 2022 Share Posted January 14, 2022 Youtube has started putting plastic weld videos on my feed. Probably after reading this thread 😁 Has anyone tried doing this for the broken tabs or is it too much hassle ?? There's a comment on the first vid about using wire mesh to reinforce the break then (I presume) filling in with the plastic rods Quote Link to comment Share on other sites More sharing options...
