PhilC85 Posted June 22, 2019 Share Posted June 22, 2019 I have an oil leak from the end casing gasket on the gearbox of my 1.6 Zetec Manual 61 plate MK3 focus, I'm struggling to find the part numbers or any info at all for the parts circled in the attached image. Is anyone able to help out please? I've scoured the Haynes manual with no results. ** Image is of Fiesta as cant find the correct diagram for the mk3 Focus. Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted June 22, 2019 Share Posted June 22, 2019 Find all the part numbers on here. https://ford.7zap.com/en/car/ 1 Quote Link to comment Share on other sites More sharing options...
PhilC85 Posted June 22, 2019 Author Share Posted June 22, 2019 15 minutes ago, iantt said: Find all the part numbers on here. https://ford.7zap.com/en/car/ Thanks for that, am I correct in saying its parts 7L301, 7B343 & 7211 to complete the full seal as the rest of the gearbox is a solid unit? Thanks for the guidance Quote Link to comment Share on other sites More sharing options...
iantt Posted June 22, 2019 Share Posted June 22, 2019 7l301is the gearbox casings. So you won't need that. Are you sure it's leaking from both gaskets? Gaskets are 7223 and 7b343 Quote Link to comment Share on other sites More sharing options...
PhilC85 Posted June 22, 2019 Author Share Posted June 22, 2019 59 minutes ago, iantt said: 7l301is the gearbox casings. So you won't need that. Are you sure it's leaking from both gaskets? Gaskets are 7223 and 7b343 From what I can see its leaking from drive shaft seal and that also heres a few pics, I'm no mechanic like could do the job myself though so want to try work everything out that I need etc Quote Link to comment Share on other sites More sharing options...
