tholden Posted July 21, 2019 Share Posted July 21, 2019 Hello Does anyone have any idea about these error codes? Found them from the secret test menu. Ford is 2008 1.4 tdci P203a P0150 P0244 P0248 P0505 P1101 P133C P133A P1630 P1941 P203A Quote Link to comment Share on other sites More sharing options...
tholden Posted July 21, 2019 Author Share Posted July 21, 2019 Not sure if all of these are error codes as the secret menu is not very descriptive. I initially thought it might be the diesel filter, but i saw in the service papers that it was replaced last year, so not so sure anymore. Quote Link to comment Share on other sites More sharing options...
isetta Posted July 21, 2019 Share Posted July 21, 2019 reading the codes for the first time does tell you a lot as codes can be there for a very long time from previous problems that no longer exist. All codes need to be cleared, then drive it and see which ones come back. It's a shame cars don't record the dates with the codes. Quote Link to comment Share on other sites More sharing options...
tholden Posted July 21, 2019 Author Share Posted July 21, 2019 I had the codes cleared when I got the injector seals fixed three months ago. So they should all be fairly new. Also, none of these codes where apperant when the mechanic cleared them. Only two injector related codes was stored in the system at that time. The car seems to only chug when its warm and when under extra load, such as going uphill. It happenes at about 2300 rpm if that matters. Car has 74K km on the clock. Quote Link to comment Share on other sites More sharing options...
tholden Posted July 23, 2019 Author Share Posted July 23, 2019 I dont know if these codes are even real. Went by the dealer, and they said there were no codes. Strange. They said the problem might be caused by EGR, MAF, O2 or injectors. Dont know if there is any point having them do testing before an error code is registered? Fuel filter and air filter is recently changed. I changed the air filter today but it did not solve the issue. Quote Link to comment Share on other sites More sharing options...
