Baillie Evans Posted July 23, 2019 Share Posted July 23, 2019 hi i have a 2ltr cmax auto 2006 with a vibration when pulling away slowly from stop it vibrates through the bulkhead were the gear shift is situated it does this up to about 25 mph then is no problem it has had all new engine mounts fitted near side and off side wish bones, near side and off side drive shafts. new front disc and pads and a new offside front spring top hat, but the vibration is still there. H as anyone expeienced this problem if so how did you get rid of problem please. Contact Mrlexus1998@gmail.com asap please. All wheels have been balanced new discs and pad on rear 2 new rear shock absorbs and springs, also front has had new springs thankyou Quote Link to comment Share on other sites More sharing options...
pragmatix Posted July 23, 2019 Share Posted July 23, 2019 I suspect the gearbox. Quote Link to comment Share on other sites More sharing options...
Hostahousey Posted July 24, 2019 Share Posted July 24, 2019 Or clutch. Quote Link to comment Share on other sites More sharing options...
pragmatix Posted July 24, 2019 Share Posted July 24, 2019 2 hours ago, Hostahousey said: Or clutch. Its an automatic Quote Link to comment Share on other sites More sharing options...
Baillie Evans Posted July 24, 2019 Author Share Posted July 24, 2019 thank you all for your responces i have had the gearbox checked out and no problems found it has my mechanic of 40 years traiding a bit perplexed hope someone out there has the answer cheers Quote Link to comment Share on other sites More sharing options...
Hostahousey Posted July 25, 2019 Share Posted July 25, 2019 21 hours ago, pragmatix said: Its an automatic So..Are you saying autos don't have clutches ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 25, 2019 Share Posted July 25, 2019 34 minutes ago, Hostahousey said: So..Are you saying autos don't have clutches ? It depends whether it's a conventional auto (torque converter) or whether it's a 'semi' auto like Powershift or DSG (clutches). I think this will be a full auto box though. I'd still suspect the 'box myself, has the fluid & filter been changed or has the 'box just been checked for fault codes? Quote Link to comment Share on other sites More sharing options...
pragmatix Posted July 25, 2019 Share Posted July 25, 2019 1 hour ago, Hostahousey said: So..Are you saying autos don't have clutches ? They do have clutches but not in the same way manuals do. Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted July 25, 2019 Share Posted July 25, 2019 We know this is a 2.0 auto but can't see any mention of petrol or diesel? I believe Ford swapped boxes a fair bit on the C-Max but have an idea that 2.0 petrols got a (Mazda derived?) torque converter and diesels the powershift (dual clutch) box. I have seen reports of judder/vibration with these, and the VW dsg, particularly if transmission oil changes have been neglected as @TomsFocus mentions. Quote Link to comment Share on other sites More sharing options...
Hostahousey Posted July 27, 2019 Share Posted July 27, 2019 On 7/25/2019 at 9:20 AM, pragmatix said: They do have clutches but not in the same way manuals do. So it could be a clutch fault then. Mine is an auto powershift double CLUTCH. Quote Link to comment Share on other sites More sharing options...
Hostahousey Posted August 15, 2019 Share Posted August 15, 2019 Any luck finding the fault ?? Quote Link to comment Share on other sites More sharing options...
