Treef Posted July 25, 2019 Share Posted July 25, 2019 In other cars I've owned after running the a\c you get water running out of a drain to the outside, on my 2012 Fiesta Titanium this does not happen so I am wondering if the drain is blocked but I don't know where it's located. I have had a feel around the footwells and they are dry so the condensation must be going somewhere. Quote Link to comment Share on other sites More sharing options...
Bobr Posted July 25, 2019 Share Posted July 25, 2019 Mines exactly the same but the air con works perfectly. First car with air con I've had that doesn't get water under it. Quote Link to comment Share on other sites More sharing options...
Eatonm112 Posted July 25, 2019 Share Posted July 25, 2019 I have the same car and mine usually has a puddle of water under the car when I have the AC running it is very noticeable on humid days. It does depend on the weather/humidity in your area I spend most of my time in London and around it. The drain pipe is under the center console you can take the side off it and you'll see its made of black rubber. Quote Link to comment Share on other sites More sharing options...
Treef Posted July 25, 2019 Author Share Posted July 25, 2019 Thanks for that, I will have a look when it gets cooler and see if It's blocked Quote Link to comment Share on other sites More sharing options...
