nivek24 Posted July 26, 2019 Share Posted July 26, 2019 I have no spare wheel in my 2014 fiesta 1.25, it's got std 15" 4 stud steel wheels, does anyone know for sure if the Focus full wheel or space saver will fit, not the alloys,steel ones. kev Quote Link to comment Share on other sites More sharing options...
Westville Posted July 26, 2019 Share Posted July 26, 2019 You will need to consider the rolling radius of the "spare" wheel ideally should be the same as the existing wheels (ie the size of the wheel and tyre combined) It will obviously need to fit on your studs and hub so you need to know some info about the wheel's PCD, Offset and tyre width and depth Have a look at the many calculators available on the web to see what effect wheel and tyre sizes have on the offset and size of your "spare" - I use this one which gives you graphic information and also measurements for both old and new wheels https://www.willtheyfit.com/ HTH Quote Link to comment Share on other sites More sharing options...
isetta Posted July 26, 2019 Share Posted July 26, 2019 Focus mk1 is four stud. Focus mk2 onwards is five stud fitting. The mk1 focus wheel will go on there (bolt holes are correct) but focus normally has taller tyres compared to what a fiesta would have on same size wheel so I am not sure if you would get problems with tyre rubbing particularly when turning sharp. The normal spare for your car would be 4 stud fixing 175/65/14 which has been used on fiestas since 2002 as the main wheels on the car on lower spec models and spare wheels on higher spec models. Easily available on eBay etc. Quote Link to comment Share on other sites More sharing options...
nivek24 Posted July 26, 2019 Author Share Posted July 26, 2019 50 minutes ago, isetta said: Focus mk1 is four stud. Focus mk2 onwards is five stud fitting. The mk1 focus wheel will go on there (bolt holes are correct) but focus normally has taller tyres compared to what a fiesta would have on same size wheel so I am not sure if you would get problems with tyre rubbing particularly when turning sharp. The normal spare for your car would be 4 stud fixing 175/65/14 which has been used on fiestas since 2002 as the main wheels on the car on lower spec models and spare wheels on higher spec models. Easily available on ebay etc. So if i understand this correctly, the 14" focus wheel will fit ok even though mine are 15", will it not effect the car stability. If i got a space saver would this 14"or 15" thanks kev Quote Link to comment Share on other sites More sharing options...
Westville Posted July 26, 2019 Share Posted July 26, 2019 Try the website I posted earlier Smaller size spacesavers are common e.g. on my Edge I have 20" alloy wheels but the "spacesaver" is 17" steel wheel - it is the tyre that makes up the difference in height to keep the overall wheel and tyre radius the same Quote Link to comment Share on other sites More sharing options...
