VFR800
MK4 Charger pad woes
Do you have a MK4 with the charger pad? Do you constantly feel like throwing the charger pad out the window because all you seem to get is the message "charging has terminated due to the ***** design of the charging pad in the MK4 Focus!!!"
I purchased some SUGRU (mouldable rubber, they call it glue.) and bish bash bosh..... It aint pretty but let's hope it works, i will keep you all updated.
I didnt go for that option after a review a saw highlighted the pad as one of the few things they could fault because it's very sensitive to phone movement. So i just use either a pad that fits in the same space or a very short usb lead into the adjacent socket.
Yeah i'm one of those frustrated MKIV buyers who took the option of the charging pad (it was the one option I could afford)
It's honestly ridiculous and incredibly badly designed and not fit for purpose. Not only is the charging pad charging zone quite small it also leaves a massive open area around it for the phone to easily slide of the sweet spot so you get the oh so annoying sync 3 message.
Now maybe you guys can correct me if I'm wrong but when you get that message advising you that your phone is no longer charging because it's moved 1 cm of the charging spot you then have to click 'OK' on the screen, again super frustrating, if it just stopped charging that would be fair enough as I'd probably take a corner in a minute or so and the phone would slide back into place but to have to continue to confirm that it's not charging is madness.
In addition to the feeling that you've wasted £100 on a really badly designed wireless charging pad I have now discovered another sore point.
You connect your phone via the usb cable but place it on the wireless charging pad, after all that's the space for the phone and you switch on in my case android auto however even though you're connected via cable as soon as your phone moves of the charging pad SYNC 3 throws you out of android auto to inform charging has terminated..aaaaagggghhhhh
Honestly I just want to disconnect it so I can have a standard storage bin for a phone where I can use android auto without disconnects and no have that nagging feeling I've been duped.
Rant over ;)
One last thing, thought I'd found a fix, I have one of those super thin super tacky phone pads, you can place them around the house or on the dash and they sort of stick to the plastic and your phone sits on top without moving. Well this sort of worked in that I placed it on the charging zone, then placed the phone on top…..got the message phone is wirelessly charging, great I thought however the sticky pad didn't stick to the wireless charging area too well, I suspect due to the dimples...…...oh well onwards and upwards.
Hi VFR800, I was thinking of a similar approach. How is this working for you?
The problem seems to also be linked to the amount of current the pad can provide and also the temp of the phone. I've got a Samsung NOTE 8, fitted with a 3300mAh battery. If it's over approx 90% charge and over 24 degrees centigrade the phone will charge for about 30 seconds then stop, with the misaligned error. The phone now stays in place no matter what. I'm also checking to see if the charger socket in the same location is on the same circuit and may also cause the charge current for the pad to be limited.
A long term test scenario.
  Only 75 emoji are allowed.
