Duggy
FORD FOCUS 1.6 TDCI 2006 ENGINE MANAGEMENT LIGHT
Hello, the engine management light came on in my car a few days ago. Used Forscan and it was indicating that the eolys fluid needed refilling. I have refilled the eolys with 1ltr of fluid and then through Forscan did the following: FACM Refill the Fuel Additive Tank and then FACM Fuel Additive system Prime. I then tried to FACM Module reset, but it "Service Procedure Not Supported". I also tried to do a DPF Static regeneration but would only go so far before it was interrupted an wouldn't continue. My engine management light is still on. Have drove it 10 miles already with no visible problems, but I would really like to know if I can clear this warning light?
Below is all the codes that are coming up after I had done all the work. Thanks in advance for any help.
  Only 75 emoji are allowed.
