Please help fault and nobody knows what
Kieranwinter
2014 diesel galaxy, when driving on motorway I get engine service now on dash, put foot down abit and get traction light on and abit of over rev, limited transmission comes on the dash then followed by eml, fault codes say fuel leak major and fuel leak minor, there is no fuel leak tho so very confused!
Could be any number of things you need to try and narrow down the options - since the fault codes are suggesting fuel as the problem I would start by having a look at the fuel system - a good place to start in these days of sticky supermarket diesel is the fuel filter - for a few quid it is always worth changing that especially if it has been a while since it was done.
If the filter is clogged or dirty it will cause fuel flow problems which can trigger dashboard warnings and EMLs as the engine tries to figure out what is causing intermittent performance often followed by vague fault codes
Hope that helps
It was serviced around 4-6 weeks ago full service, could it be a cheap filter?
Over revving and limited transmission sounds like a Powershift fault.  Is it just a generic OBD reader giving you those codes?
I’ve scanned myself with forscan and also my friend works for ford and was scanned by there laptop and brought back same codes
P1719 is also another code I’m getting
Did they actually replace the filter?
In my experience what they say they do and what they do are not always the same :whistling:
