zain611 Posted August 8, 2019 Share Posted August 8, 2019 Just trying to find some thin plate holders for the car. Don't really like those ones you see with the wide bottom part for advertising. Thought one of you guys might help look for me. Seen these 2 here https://www.amazon.co.uk/dp/B0102N7QN8/ref=cm_sw_r_cp_apa_i_TeitDbJG7SRS5 https://www.amazon.co.uk/dp/B07QWT2Q4J/ref=cm_sw_r_cp_apa_i_sZitDbYY8MKV3 Really want it to look like this one where it looks to be no hooks on the edges Quote Link to comment Share on other sites More sharing options...
LondonFiesta Posted August 9, 2019 Share Posted August 9, 2019 Having had two cars’ plates pinched in less than a few years, I’d be looking to make it harder to remove than easier. It’s a huge pitaFor what you want they look fine. Have you thought about just tape on the back if you want a clean look? 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 9, 2019 Author Share Posted August 9, 2019 2 minutes ago, LondonFiesta said: Having had two cars’ plates pinched in less than a few years, I’d be looking to make it harder to remove than easier. It’s a huge pita For what you want they look fine. Have you thought about just tape on the back if you want a clean look? I have those adhesive pads but just worried about it falling off hence why I'm looking at a plate holder. Mainly want it to be discreet. Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted August 9, 2019 Share Posted August 9, 2019 20 minutes ago, zain611 said: I have those adhesive pads but just worried about it falling off Had several cars that came with the plates fitted invisibly. I presume they had been fitted with pads but never got to check as none ever came off! One car we had stayed in the family for 13 years without a problem with the plates. Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 9, 2019 Author Share Posted August 9, 2019 27 minutes ago, Eric Bloodaxe said: Had several cars that came with the plates fitted invisibly. I presume they had been fitted with pads but never got to check as none ever came off! One car we had stayed in the family for 13 years without a problem with the plates. Might seen then 😅. Is the bumper on your car curved? I did end up buying the first plate holder in the original post above. My dad is just worried about the plates falling off from the adhesive pads. He's experienced it himself with his car where it fell off twice whilst it was parked. This is the pads I have. Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted August 9, 2019 Share Posted August 9, 2019 Just now, zain611 said: . Is the bumper on your car curved? The car I have now is fixed with screws. The ones I mentioned all had flat areas on the tailgate/boot, front bumpers normally have some flat area(s) where the number plate mountings are, so I guess they used pads on those in place of the screws. 1 Quote Link to comment Share on other sites More sharing options...
LondonFiesta Posted August 9, 2019 Share Posted August 9, 2019 You can get 3M ones from amazon or Halfords. That plate won’t be going anywhere with that. 1 Quote Link to comment Share on other sites More sharing options...
Westville Posted August 9, 2019 Share Posted August 9, 2019 I only use 3M pads like these https://www.ebay.co.uk/itm/Number-Plate-Sticky-Pads-Strips-Double-Sided-Tape-Self-Adhesive-Strong-x-6/113593947993?epid=2099923245&hash=item1a72ba1759:g:BAsAAOSwJD1ccbb- Had too many fails with cheaper non-branded ones 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 9, 2019 Author Share Posted August 9, 2019 21 minutes ago, Westville said: I only use 3M pads like these https://www.ebay.co.uk/itm/Number-Plate-Sticky-Pads-Strips-Double-Sided-Tape-Self-Adhesive-Strong-x-6/113593947993?epid=2099923245&hash=item1a72ba1759:g:BAsAAOSwJD1ccbb- Had too many fails with cheaper non-branded ones What's you experience with it? Might go down Halfords to have a look. Probably just going to use that plate holder I bought. Might see if its possible sticking the rear plates on but again the tailgate screw holes are lifted a bit so i think the plate will only make contact in those two small areas. Quote Link to comment Share on other sites More sharing options...
Westville Posted August 9, 2019 Share Posted August 9, 2019 3M pads are great as long as you use them properly and use enough evenly spaced out to grab the plate I've used them on the plastic plate holders like Ford's fitted to my Edge and also directly onto the front and rear bodywork Because the crap pads supplied by my number plate maker failed recently I had no option but to use screws and caps to secure the plates - otherwise I would have "stuck" with 3M Don't be tempted to buy Halford's own brand sticky tape either as pads or on rolls - it's not up to the job in my experience 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 13, 2019 Author Share Posted August 13, 2019 So to update I bought the first plate holder I linked in the original post. To be honest it looks nice hopefully the plate will look good in it which I'll update on. DEZENTOFIX CMS License Plate Holder - Top RatedBESTSELLER from Germany, 2 Pieces -NEW! - The long expected DISCREET Solutionfrom GERMANY! https://www.amazon.co.uk/dp/B0102N7QN8/ref=cm_sw_r_cp_apa_i_a-TuDbN0H8QJ0 Quote Link to comment Share on other sites More sharing options...
