Bubbling Paint Correction
Hi All,
My beloved Focus is starting to show a few signs of minor paint bubbling and I won't to sort this out before the rust takes over (I have recently fitted a new O/S wing because it was cheaper to replace than repair).
I have done some minor car painting in the past using water based paints / clear coats but am by no means a professional.
What options do I have to rectify these issues? Will it be a case of rubbing down all the effected areas, priming, base coat and then clear coat or is there a better, less toxic option available (I would want to use 2K as the water based materials just don't cut it - and yes I'm aware of the PPE required)?
Any and all help would be most appreciated! As I said it's not a full car respray, just small areas about 20m㎡.
Cheers, Stophen.
