Wuly1554 Posted August 11, 2019 Share Posted August 11, 2019 Hi just used my wife's fusion and noticed I was getting the noise you get when you need to replace indicator bulbs . Checked bulbs by swapping with working ones for the other side and got nothing. The strange thing is I have no main or dipped beam no indicator and when I switch main or dipped beam on my side repeater comes on permanently without using indicator switch. Quote Link to comment Share on other sites More sharing options...
isetta Posted August 16, 2019 Share Posted August 16, 2019 if this was mine I would be suspecting a faulty earth. To test that I would connect a spare piece of wire from the negative (earth) terminal of headlamp bulb holder to an earth point where there is some bare metal (probably more easily found on engine eg. alternator casing - you might need to clean surface to get good connection). that would test if that is the fault and then do something better as the fix. (for anyone reading this who is not familiar with car electrics, the Earth on a car is not like the earth on your home mains power. The Earth on a car is effectively the negative power supply terminal) Quote Link to comment Share on other sites More sharing options...
