Focus Mk2.5 LED Fog Light Bulbs
Good afternoon. I am looking for advice on which LED bulbs to fit as fog lights, but to use mainly as DRL`s with the side lights on.  Seen quite a few different ones on ebay but unsure what to buy.
What can people recommend?
Thanks.
Go with a brand name such as Phillips or Osram, you'll get a better result and longer lifespan. I use Osram in the rear lights, not touched the front lights yet but one consideration is look at a 'surround' driving light rather than replacing the bulbs in your fog lights. They're fairly easy to fit, and I believe there's a guide here. They usually either replace the fascia round the fog light or bolt into the existing bodywork.
Thanks.
I've got cree H11 fitted but they affect the radio reception perhaps some sort of radiation,
Have you saw the DRL fog surrounds ?
They work very well click the link below as he image is not the DRL I'm talking about
Here they are:
394578176_Screenshot_20190811-201107_WriteonPDF.thumb.jpg.c1cb559f421d5e048269f9725622280d.jpg
You should be aware that fitting bright LED bulbs make them useless as 'fog' lights, but as you state you want to use them as DRLs, you'll be fine.
