Zee_3 Posted August 12, 2019 Share Posted August 12, 2019 Hello, Anyone here upgrade factory sound, perhaps know the size of the back Speakers? Around 6.5"? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 13, 2019 Share Posted August 13, 2019 11 hours ago, Zee_3 said: Hello, Anyone here upgrade factory sound, perhaps know the size of the back speakers? Around 6.5"? Thanks! Hi, Ive upgrade my entire sound system to aftermarket The best way to find out is on eBay as you will need model specific to aftermarket speaker adapters, I don't know what model you have but I searched for "mk2 focus aftermarket speaker adapters" which fills the factory hole then provides a 6.5" hole for an aftermarket speaker, Search your model on eBay for aftermarket speaker adapters; there different shape for front and rear doors, Then see what size of speaker the aftermarket adapter takes as that's then the size you will need. Quote Link to comment Share on other sites More sharing options...
Zee_3 Posted August 13, 2019 Author Share Posted August 13, 2019 Hey! *****, I should've mentioned I have a fiesta MK 7. But thank you, this does help however! 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 13, 2019 Share Posted August 13, 2019 I think it's 17cm. Heres an eBay ad of some front focal Speakers which says for a mk6 fiesta. I think focal are the best in the game. https://www.ebay.co.uk/itm/Ford-Fiesta-2001-2008-Focal-17cm-Front-Door-Speaker-Upgrade-Kit-/172228731576 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted August 13, 2019 Share Posted August 13, 2019 2 minutes ago, Zee_3 said: Hey! *****, I should've mentioned I have a fiesta MK 7. But thank you, this does help however! Probably the same size. Something to point out some speaker listings say 16cm whereas some say 17cm. 1 Quote Link to comment Share on other sites More sharing options...
Zee_3 Posted August 13, 2019 Author Share Posted August 13, 2019 3 minutes ago, zain611 said: I think it's 17cm. Heres an ebay ad of some front focal speakers which says for a mk6 fiesta. I think focal are the best in the game. https://www.ebay.co.uk/itm/Ford-Fiesta-2001-2008-Focal-17cm-Front-Door-Speaker-Upgrade-Kit-/172228731576 Hey, I see those are front. I have my fronts upgraded already with a split system. Upgrading the back this week. So just needed to confirm the back size. 1 Quote Link to comment Share on other sites More sharing options...
Static Posted August 13, 2019 Share Posted August 13, 2019 Mark 7 is same front and rear: http://www.caraudiodirect.co.uk/ct25fd10-ford-speaker-adaptors I used these adapters on my fronts but they listed for rear too 1 Quote Link to comment Share on other sites More sharing options...
Zee_3 Posted August 13, 2019 Author Share Posted August 13, 2019 17 minutes ago, Static said: Mark 7 is same front and rear: http://www.caraudiodirect.co.uk/ct25fd10-ford-speaker-adaptors I used these adapters on my fronts but they listed for rear too Good to know! Thank you!! 1 Quote Link to comment Share on other sites More sharing options...
ThaiFiesta Posted August 13, 2019 Share Posted August 13, 2019 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302279451570 These will save having to cut and solder. Quote Link to comment Share on other sites More sharing options...
Zee_3 Posted August 13, 2019 Author Share Posted August 13, 2019 12 minutes ago, ThaiFiesta said: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302279451570 These will save having to cut and solder. I've just had all my wires spliced instead, in order to retain factory Speakers when/if ever needed. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 13, 2019 Share Posted August 13, 2019 4 hours ago, Zee_3 said: I've just had all my wires spliced instead, in order to retain factory speakers when/if ever needed. 1 1 Quote Link to comment Share on other sites More sharing options...
