vindi93 Posted August 15, 2019 Share Posted August 15, 2019 Ok i have a very annoying click noise everytime i pull away. No noises when i turn left or right. Or when braking. Only when i pull off forward or reverse click click. Changed both gearbox mounts so it isnt that. Once your moving and changing gear i dont hear anything. Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Russ Posted August 15, 2019 Share Posted August 15, 2019 8 hours ago, vindi93 said: Ok i have a very annoying click noise everytime i pull away. No noises when i turn left or right. Or when braking. Only when i pull off forward or reverse click click. Changed both gearbox mounts so it isnt that. Once your moving and changing gear i dont hear anything. Sent from my SM-G920F using Tapatalk You sure it isn’t the ABS ‘self test’ your hearing. When you first pull away, at around 12mph you can hear the ABS making a click/clunk type noise. (It can be loud or quiet depending how hard/fast you pull away) It sounds like that’s all your hearing (natural and nothing wrong) as you say it’s only when you first move off after starting the car. Quote Link to comment Share on other sites More sharing options...
vindi93 Posted August 15, 2019 Author Share Posted August 15, 2019 You sure it isn’t the ABS ‘self test’ your hearing. When you first pull away, at around 12mph you can hear the ABS making a click/clunk type noise. (It can be loud or quiet depending how hard/fast you pull away) It sounds like that’s all your hearing (natural and nothing wrong) as you say it’s only when you first move off after starting the car.Only on the left hand Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Comares2001 Posted August 16, 2019 Share Posted August 16, 2019 Poss drop link noisy but not worn . I've had this before including on new Mk4 I have now . Try opening up rubber boots on ball joints and spraying in white grease or ptfe lube. Quote Link to comment Share on other sites More sharing options...
vindi93 Posted August 17, 2019 Author Share Posted August 17, 2019 Poss drop link noisy but not worn . I've had this before including on new Mk4 I have now . Try opening up rubber boots on ball joints and spraying in white grease or ptfe lube.Interesting i have noticed i can also hear it under hard acceleration in 2nd gear too.Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Russ Posted August 17, 2019 Share Posted August 17, 2019 On 8/15/2019 at 8:53 PM, vindi93 said: Only on the left hand Sent from my SM-G920F using Tapatalk The ABS unit IS on the passenger side of the car therefor if it is the abs unit self test then it will only be heard coming from that side. Quote Link to comment Share on other sites More sharing options...
vindi93 Posted August 17, 2019 Author Share Posted August 17, 2019 The ABS unit IS on the passenger side of the car therefor if it is the abs unit self test then it will only be heard coming from that side.From 12ft away and over 20mph. Sent from my SM-G920F using Tapatalk Quote Link to comment Share on other sites More sharing options...
red_october Posted March 5, 2021 Share Posted March 5, 2021 On 8/16/2019 at 1:20 PM, Comares2001 said: Poss drop link noisy but not worn . I've had this before including on new Mk4 I have now . Try opening up rubber boots on ball joints and spraying in white grease or ptfe lube. Sorry to bring up this old thread but I've got a Focus Mk4 1.5L ecoboost (or SA series as it's known here in Oz), and I hear a very soft click almost everytime when I hit the accelerator. Not all the time though. Only done 10350kms. Any idea what the issue might be? Quote Link to comment Share on other sites More sharing options...
